I got new bearings for mines just in case. Was able to get oem parts for $500 and labour was $200 per side. So total job was $900 plus rear brake shoes
Youch. I can't believe the cost of living in Canada. Pay rates must be substantially better than in the US.
Tell me about it. Everything in Canada is generally more expensive. My car insurance is $400/month including my 4runner and protege. The housing market is insane, average detached and semi-detached homes here in Toronto are at least 800k. A 1 bedroom condo is now minimum 300k
If you are doing all the work to disconnect the brake lines, drain diff fluid, pull shafts and clean up / replace the shoes... why not change the bearings? IMO foolish not to as the bearings do not cost that much. Do it right and you are in for the long haul.
For the AZ people, I offer press work or the full job:
- $150 for press work if you bring me your axle shafts and new bearings
- $650 for the full job out the door which includes nachi bearings, oem seals, oem shoes & fluids (valvoline gear and brake fluid). I also maintenance or replace stock breather depending on the condition.
Just offering side work to help pay for new tools, shop toys and family needs.
Why would you drain the diff fluid to change the seals? ***EDIT*** Guess it all depends on how you've been using the truck and the maintenance schedule you're on....obviously, if you've been driving in dusty environment or through deep water once the seal's gone bad....you're diff fluid is likely to be contaminated. I caught mine before it really even started dripping down the drums.... My point was: when you jack up one side at a time, the gear oil isn't going to leak out. I didn't spill a drop out of the housing when I changed seals. ***
I had a seal start leaking immediately after a kid working at the tire shop beat the bajeezus out of the drum with a huge hammer to get it off. :redbrick: The tire shop insisted that a bearing had to be pressed out to replace the seal. :ybrick: I then had the seal replaced at a dealership with no bearing removal necessary. Been good so far about 10k miles.
Anyway to anyone doing this, I would get some extra retainer rings in case you need to cut it off so that you can leave more of gap between it and the ABS ring and/or reverse the bevel. If my seals leak again I will be doing that. Stupid Toyota and their stupid ass redesigned seal.
