back firing and running extra rich
Yes i have readed everything about running rich conditon
I have a 1995 4runner 3.0
i have replaced the 02 sensors
checked exhuast leaks / none
Done a tun-up / plus,wires,cap,rotor,air fitler
cleaned the throttle body
timing is on point
replaced the coolant temp sensor and switch
replaced the tps
checked for vacuum leaks/none
changed the MAF
replaced the CAT
I did a compression test on all cylinders / 170+
I have let to test the cold start injector and the normal injectors but they do look like they have been replaced recently
I need help, my truck starts and idles amazing and likes its suppose to, but is blowing back smoke out of the exhaust, i need help and on what else i should check or replace to make this stop, i hate it, it sucks. there is no back fire
please if anyone else has had this problem before, please let me know how you replaced it and fixed it.
Last time anything of mine blew black smoke, it was the engine coolant temp sensor, which you said you've replaced. Any chance you got a bad one? Have you checked the resistance on the new engine coolant temperature sensor?
yea i have and it was bad so i bought a new one by BWD and doesnt suck or isnt a bad one, and iv replaced all those coolent temp sensors on that water bypass outlet, they sit in
31ectr0nicb0b
