Back window stick. Help
KENGNJ
So we stopped for lunch at the park, hauling the camper. Can't open the rear door as there isn't enough clearance between the jack and the door. So we used the rear window. It went down fine, but now won't go up. Any idea how to fix this?? Still have a couple of hours left to tow before getting home.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Can you hear the motor trying to push the window up? If not, possibly a blown fuse.
Maybe turn it off and back on again? Works with my computer sometimes. Once I even kicked it and it started working, contrary to what my mom told growing up.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Ok I was able to get the back window to go up using the key in the hatch, but the switch upfront still doesn't work. Did I blow a fuse, or a switch? Well at least we can continue with out a breeze
Glad to hear you got it sorted out. Please let us know when you figure out what went wrong.
I once had the same issue...check the window lock. I thought something was wrong til i saw that the lock was engaged.
Happens to me all the time on my other vehicles actually. I'm sitting there trying to roll windows up or down and I'm like "Why won't they work?!" Then I realize I have the window lock engaged...haven't accidentally tapped it in the 4Runner yet though.
Bunkstaff
