Back window troubles
tucktuck8
So my back window switch by the steering wheel won't roll down the back window but the button on my key will. Any suggestions on a fix?
Will it roll the back window up? If it will roll it up, but not down, probably just a bad contact in the switch itself. Have you recently done any work to your T4R?
did you happen to check if the passenger window lock button on the driver door is enabled? that would disable the back window, at least on mine.
Excellent point! You are correct. If the window kill switch is enabled, then the dash mounted rear window switch is disabled. It's like that on ALL 4th gen's.
It was the window lock button that wouldn't allow it to go down. It functions perfectly now. Thanks guys! At least this question is now archived in google search for other dummies to figure out. Thanks again.
Opposite situation
So as of today my window is doing the opposite. The button on my key fob will no longer roll down the window but the dash switch will. BUT even using the dash mounted switch for the back window it has lost its auto down/ auto up function. It use to go down all the way with a single long touch and up all the way with a long touch. Now I have to hold it the whole way down or up. That happened the exact same time as the key fob window button stopping working. Worked yesterday but not today. Any thought?
Did you jump start the car recently or change the battery? Does the drivers window up and down auto work? You may need to relearn the auto. Roll the window all the way up and down three times in a row and see if it works.
