Backup LED lights upgrade
I don't believe Rigid makes replacement bulbs for your stock reverse lights? Correct me if I'm wrong but they have noting like this on their site.
Thanks RaisedByWolves
Ha yea being a bit facetious but seriously an LED swap won't turn the lights on for backing up. Resolution on the cam just isn't good enough.
Being serious, the rigid inserts by cutting into the bumper is your best shot if you're looking to throw out some noticeable light.
I recently bought and installed the 921 Putco Plasma LED Replacement bulbs from Xenon Depot and have to say what a disappointment. I find very little added light for when backing up a trailer.
I'm currently looking at buying the Tail as Turn module from Diode Dynamics. This changes the rear turn signal bulb into an additional backup bulb and uses the brake light as a turn signal.
I have been paying attention on the roads and noticed that Dodge Ram and Ford F150 have the brake light also as a turn signal using the same bulb and only one bulb in the housing.
Check out diode dynamics website and on youtube. It's called turn-as-tail light kit might just be what your looking for. Thinking about getting these for mine.
I put these in a couple weeks ago, huge difference! Certainly not a set of Rigids, but much cheaper, and still plenty of light.
JDM ASTAR 912/921 800 Lumens
Forgot I took a picture the other night in a well lighted parking lot.
Sent from my SM-G930V using Tapatalk
Backup light
In the process of making a rear step-bump bar to install in hitch receiver. It's all stainless, have the basic bar done. Going to install some kind of backup lighting in it. Probably going with the Ridged Radiance , red back-light in either the 10" or Pods. Two pods are cheaper but the 10" may work a little better for what I've got in mind.
I went with the tail as turn mod and bulbs from Diode Dynamics... I can do a write up if anyone is interested.
delislerebecca
