Bad Luck's Boring Build Biography
[MENTION=319302]Bad Luck[/MENTION], Heads do look good, any idea what oil was used ?
Mine @200k had darker oil stains just as clean, PO religious with oil changes at quicklube with house oil non syn.
Got me to thinking, is it frequency or oil quality.
Did you use ultra sonic cleaner ?
[MENTION=139000]phattyduck[/MENTION], I like that after pic.
Been running T4 25k mi pulling covers soon so I'll get to see the results.
I looked through some of the more recent records in the folder and it shows oil changes every 5Kish miles with full synthetic 5W30 at Firestone. It doesn't say what brand of oil though. We have a heated parts washer at work that's almost like a dishwasher. Put the valve covers on a tray and it shoots hot (150*F) degreaser on it while the tray rotates. I did that for about 40 minutes while I was busy cleaning the old gasket material/sealer off, and changing the cam plugs and half moons. Then a light scrub with the parts washer wand was all it took.
I'm a fan of frequent oil changes and have my oil service interval on my UltraGauge set for 3500 miles reminder. (I use synthetic 5W30 and Toyota oil filters, but at that short of an interval I'm sure conventional would be fine.)
Didn't feel like verifying the valve clearances on this round? I don't blame you. I would though when over 250 to 300k miles. I have to check mine when I do my valve covers at 300k.
Sent from my SM-A505U using Tapatalk
I considered it, but decided to wait until I have to do the timing belt in case I decide to pull the camshafts to make it easier to check and adjust the valve clearance.
Yes that's the issue I have. I had a bad water pump so I did the timing belt a little while ago so at 300k. My timing belt will still be good. So I have to just pull it off to test the valve clearances. I wish toyota would have made it easier to do. Granted they reduced the valve clearances intervals checking dramatically by doing it this way as well. So it is what it is.
Put the valve covers on a tray and it shoots hot (150*F) degreaser on it while the tray rotates. I did that for about 40 minutes Then a light scrub with the parts washer wand was all it took.
Nice to have access to that cleaner I did once upon a time.
I'll stick with Rottela T4 & Toyota ZZD3 more than likely.
I would think some engine performance would come back some too with the valves in the proper clearance values as well. :-)
No doubt back to square one most cases.
It's worth doing I'm not willing to do it in engine bay, Lol.
Nearing time where pulling engine for other things. More CC's.
Yes there is alot easier to work on pulled. I resealed a engine when I swapped one in one of mine.
I spent most of my Sunday driving. I drove to the Arkansas/Mississippi border about 3 hours away to buy a front and rear axle from [MENTION=142122]96RedRunner[/MENTION]. (Thank you again by the way!) Then drove back, unhooked the trailer, ate a late lunch, then drove an hour and a half to Russellville to meet someone that was selling a 98 V6/manual/4wd to test drive. It was in a little rougher shape than I was hoping for and ultimately ended up not buying it. I did learn some important things while test driving it:
-Grey interior is even worse looking in person (in my opinion).
-Non sunroof headliners have so much more headroom! I’m jealous!
-I definitely have a slight input shaft bearing noise in my current transmission.
-Clutch engagement point is roughly the same.
-Clutch start switch engagement point is roughly the same.
-My engine rpm’s remaining high while coasting in neutral is not normal (or at least this one didn’t do it).
-Victory 4x4 roof rack makes more wind noise than I would be willing to tolerate. Not that I actually need or want a roof rack, but it’s nice to know for the future.
On the drive to pick up the front and rear axles I got 19.7 mpg towing a 6x12 single axle utility trailer without a tailgate. Not bad! I only got 17.6 mpg on the way back though which is still pretty good in my opinion. About 7 miles into the return trip I hit a ridge in the road that I thought was going to catapult me to the moon. It ended up shifting the rear axle on the trailer enough to where the wood blocks it was on shifted from underneath it so I had to spend 20 minutes on the side of the road in 110 degree heat index rearranging the rear axle on the trailer. The rest of the trip home went without any problems though.
The rear axle I bought doesn’t have any of the brake lines, brake cables, wheel cylinders or shoes/hardware which isn’t a problem. I’m planning on going through this axle and replacing the wheel bearings/seals/retainers and installing midcoma’s rear disc brake conversion kit. I’ve already got the pads and calipers needed to go with the kit. I did order the brake line junction for the rear axle and an axle vent valve from Toyota dealership next door to my work. They should be here any day now.
I’m still working on drywall for the kitchen/dining room renovation which has taken top priority to every other project I have going right now unless it is pressing maintenance. If anyone here is considering doing their own drywall work just don’t. I really should have paid someone to do this and saved myself a lot of time and suffering. Drywall work sucks!
It sure does. Glad you found another set of axle housings.
It's about 2 inches difference between the moon roofs and non in head clearance as I have some thar have them and some that don't.
Always good meeting T4r'ers glad return trip went mostly uneventful.
I got 17.8 mpg round trip I blame that on tires and gears difference between our rigs you did good.
The ridge in the road catapult to the moon ha that just badluck.
Here ya on the drywall, one of the few projects I leave for the folks that do it for a living. Such a messy job, one that I would rather part with a few greenbacks to get it done right and not deal with the mess.
Ya definitely underestimated how time consuming and labor intensive drywall is. Not to mention the skill required to get good results. The only real way to learn how to do it is to do it. I’m trying to convince myself that home renovation is my new hobby and drywall work is a good skill to know. I know more about drywall than I ever thought possible.
It's like body work. I only use screws to hold the drywall. The mudding and sanding the joints is the real pain. I haven't been involved in drywall project in years. I rather work in cars..lol. hang in there.:)
I probably wouldn’t hate it so much if we weren’t using our 3rd bedroom as a makeshift kitchen and the fridge is in the living room lol it wouldn’t fit through any of the doorways
DJNutshell
