Baja Designs Squadron Sport install assistance
Flat4boxer
I have a 16 TRD Pro with OEM Led fogs and am trying to install BD Squadron Sports. There are two connections off of the OEM fogs. Power only comes from the smaller connector it seems. Is there an adaptor/connector to make this hook up possible?
TIA
Edit: Finally figured it out. Kept blowing the 15 amp fog light fuse. Made some adjustments and all is good.
Mine was a simple unplug and plug back in.
You have the refreshed 5th. Mine didn't have two plugs now that I look at your picture. Hmm. Maybe @bajadesigns will chime in.
From what I can tell, the small harness powers the LED ring on the stock OEM fog. I don't have power to the regular light in the fog itself. Wondering if something is messed up with power supply to the larger harness that connects to the BD Squads :noidea:
A stock 4Runner doesn't come with LED fogs. Since you're from the southeast I'm willing to bet you have the Auer 2-in-1 LED fog lights installed by the dealer. It was a Southeast Toyota option. See if there is another wiring harness in there. I'm betting that belongs to the Auer LED fog. I would take that harness off and plug the BD harness into the stock wiring.
peacefulpiranha
