Ball joint replacement
Bingo, 45 minutes.
Done! The ones I took off were in pretty good shape. But at 201k it was worth the peace of mind. You will need a 14, 19 & 21, 24mm sockets and a couple new cotter pins.
Mind posting what links/DIYs you followed for this? Or is it pretty straight forward (few bolts and separating balljoints)?
If you end up finding someone or set up a "fix LBJ" day I'd be in to watch, help and also do mine if I have the parts by then. I'm near O'Hare and can probably get us shop space to work in (not a lot of tools though) in Schaumburg.
Well well!! This is nice! I'm up by Arlington Park so by Ohare-ish also.
After looking at some of the tools needed I don't know if I'm up to the task. The CVs might be easier first - maybe.
I'm from central Indiana (stop laughing), live in Crooked Chicago but driving is never out of the equation.
I am a young Jedi of T4R. There must be a Yoda out there.
I lived in NWI and worked in Chicago for years. Now I live just north of Indianapolis. Indiana is pretty alright by me.
Sent from my Pixel using Tapatalk
This makes me regret not repalcing my LBJs with OEM when I replaced them with Moog a few months ago. I was in a pinch for time and money and just bit the bullet. Nothing has happened yet, however I do have bigger tires and a lift so time will tell...
It's a very straight forward job. Perfect one to being to get your hands dirty on. Get a C-shape puller. Will make the job a lot easier. Another tip is that when you're tightening the 4 lower bolts on the ball joint, tighten them, lower the vehicle down to the ground and then torque them. Don't torque them while the vehicle is in the air.
Why can’t you torque them while in the air?
You want to torque them while in the air. If you put the truck on the ground and torque the 4 bolts, you will get an improper torque reading.
4runner trex girl, I did my LBJ's a couple weeks ago. Easy peasy!! I watched my buddy do the drivers side (which he had done in 5 minutes), and it took me about 15. It is really pretty easy to do, if you have basic mechanical knowledge and know-how.
A battery powered, or air powered impact is your friend!!! (not for torquing, but for removing stubborn hardware)
I'll chime in here saying that this is an easy job is you follow the video by [MENTION=120071]mtbtim[/MENTION] and [MENTION=102606]infamousRNR[/MENTION]
A long breaker bar makes short work of opening everything while a pitman arm puller separated the LBJs and OTREs like a charm.
Protip: If you start and finish one side at a time you don't have to sorry about your steering wheel possibly shifting out of center.
I used blue loctite​ and torqued the bottom 4 bolts in the air, only 67 ft lbs each, then finished the ball joint and tie rod ends and reinstalled the wheel.
When both sides were done and the car on the ground I rechecked the torque on the bottom bolts.
I used one puller, a pitman arm puller from autozone, for all ball joints - worked great. I don't like working with impact tools, I like to feel things come apart, but I will spin fasteners off with a cordless drill to save time and forearms.
You can do this job the first time soup to nuts in 1-2 hours with the proper prep and tools
Sent from my Nexus 5X using Tapatalk
[MENTION=175800]TrexRunnerGirl[/MENTION] it sounds like to me you really want to be self-sufficient with doing repairs and mods on your rig and that's a very good thing. You'll be saving tons of money while learning how to wrench and you'll get an incredible sense of accomplishment from it.
To be successful you need 3 things, a willingness to learn, tools, and knowledge. It sounds like you have the willingness to learn and you have tons of knowledge at your fingertips with the internet age. It looks like your major hangup is tools. I'm not going to lie, tools can start to get expensive especially if you have a tool buying disorder like me. But, start off with the basics. 3/8" and 1/2" ratchets, sockets, swivels and extensions. A breaker bar and some pry bars. A set of ratcheting box end wrenches. Screw drivers, channel locks, needle nose pliers, dikes cutters.
I buy most of my stuff off Amazon and base my purchases off the reviews. Stay away from the fancy brands like Snap-on. You're a DIY mechanic and don't really need to spend that kind of money on tools.
Teri, I encourage you to take up the challenge. Don't let auto mechanics intimidate you. Use the video [MENTION=102606]infamousRNR[/MENTION] and I made for this job, rent some pullers from an auto parts store and either buy or borrow the rest of the stuff you need. Is it common to run into issues when you're in the middle of a repair or mod? Yes, it's part of the experience. But, when you overcome those obstacles, it just gives you more confidence than you had before.
I look forward to hearing you report back on your successful LBJ Replacement. Good Luck Teri!
Like I said earlier in the thread, I've heard that with it in the air you run the risk of overdressing the boot. But in this thread there has been plenty of conflicting information, so don't listen to me! I will say that it's probably better to go a little under torque than over as long as you are using thread locker.
I will definitely report and post back once I get to doing it. I did the antenna by myself so now slowly to bigger parts.
Must say, even if it’s rusty and only lasts another 100k it’s worth it. I like being back in a simple, easy to fix truck.
Thanks for the kick in the britches to Git Er Done!
Sears occasionally has nice sales on full tool sets. 1/2 drive with 6 point sockets is a must, add a 1/2 torque wrench. You may have to buy a 24mm socket. Hit harbor freight or Northern for a jack and jack stands. This investment will pay for it's self 10 times over.
I always check prices for a repair at a normal local garage.
Then I know how much I'm saving if I do the job myself.
If you buy tools, it is a great invenstment. I think of it as paying for itself. With Labor being pretty expensive, buying tools never has made me uneasy.
A nice set of tools will pay for itself many times over! Good luck and keep us informed!
I hate to be a PIA, but could someone list the tools I would need. Plus what is the best kind of jack to get this puppy off the ground? And how is the torque measured - by a gauge on the wrench?
Again - I know i'll need a pry bar, a u puller, locktite, impact wrench or muscles, chocks for back wheels.
I have a socket set but probably not the best. Harbor Freight is a few miles away as is Menards, autozone, Oreilly's and the Toyota dealer.
I should change my name to PIANoob at this point. :boom:
tuṣṭāva
