Banana Holder NOW AVAILABLE
Do you need somewhere to safely store your banana?
  • Yes, I don't want my banana on the floor or in the glove box.
    Votes: 151 85.3%
  • No, I don't like bananas.
    Votes: 26 14.7%
  • Total voters
    177
My only concern is that in Texas, produce cannot be visible in vehicles. All bananas must be concealed and this might not qualify.
But thank you for thinking about my banana!
"The two widest mounting holes (the bottom two) are 14" apart. The MOLLE holes are 1.5" x 1.125" and will fit standard MOLLE accessories."
Unfortunately, there are no other mounting locations in the Toyotas. If you do drill, and ever want to go back, opening up the hole and using these little plastic hole plugs works really well. You can find them in a ton of colors and sizes and they pretty much disappear in textured automotive plastic.
Got the name or link for said plastic plugs?
Got one in. Couple of things to note.
-I had to use a make shift brake and put two small bends in the panel IOT fit the contour of the center console better. I"m guess this is why there are no pics from top down.
- i took the console apart, used nuts and washers to secure it. This required drilling out the mounting holes and was a small PITA.
- not all U.S. G.I. molle attachments are compatible. Mostly the plastic parts that are designed for the webbing of the LBE and not 1/8" thick metal. Kind of a let down as there are tons of kewl guy attachments out there and in the bottom of many of my tuff boxes. You can weave the USGI webbing into the panel, but the non milspec makes it difficult to get them tight. Kit/pouches with the old ALICE clips would be a better fit. Belt clips of course work fine.
All in all, not a terrible mod and should be very versatile going forward.
One last note. If you plan to use the nut/bolt attachment idea. Slide the panel back toward the seat about a 1/4". This will avoid the molded plastic support structure molded into the center console.
Just my .02
