Battery died today and need a good replacement
dont know if they have the standard car post or you will need to use stud to post adapter. interstate you can get at any napa or costco.
Are there any relatively affordable AGM batteries out there? Not counting Optima and Odyssy. I loveed my Die Hard Platinum in my last truck but I have come to understand that they are not made anymore. I am not in a rush, but all the decent ones seem to be in the $300 range which is way too much. I hope I am not right about the Platinum series. Still hods a good charge in a truck that has not bee run in at least tow years though I stick the charger on it every two weeks or so. Terminals are backwards for our 4th gens though. Hoping it will still be ok if I can get the cash to do a dual battery setup some day...
I think interstate AGM is in the $200 range?
I've heard really good things about Panasonic batteries... is that who makes the OEM battery from Toyota?
Also Deka batteries seem to be well regarded.
Are the CAT batteries as expensive as I think they would be? I like that option but something tells me that since they are industrial batteries they cost a premium...
Surprisingly cheap! About commensurate with the higher end batteries from parts stores. My Grp 31 HO was only $130. I priced a 27F at $112. The 31 is a threaded stud but the 27 and 24 are standard post.
Can our alternators even properly charge AGM batteries? I read they need slightly higher charging voltage than flooded batteries. If they don't get that, they won't quite charge to 100% (only about 90-95%) their lifespan could be shortened. As a result I went with a regular flooded cell battery. There are only a few companies that actually manufacture flooded cell starter batteries, so I went with Autocraft Silver since it was cheap but seems to be made to similar specs as others.
The original battery is Panasonic. They are legendary (mine lasted 10 years and still had some life left in it), but it's just about impossible to get a replacement. The Toyota True Start batteries you can get a the dealer are made by Johnson Controls, same as Autocraft Silver and many others.
If you do go Optima yellow top, don't do what I do and buy a group 35. They do fit and the website say they fit, but it's tiny and you have to use a stupid yellow spacer under it.
Get the 27F - it's bigger but fits perfectly, 200 more CCA's.
I'm still trying to sell my brand new Optima yellow top 35...gonna take a $100 loss cause i'm an idiot.
Would a yellow top be good for a daily driver?
Toyota doesn't sell the Panasonics?
The Super Start Platimun from O'Reilly is just a rebranded Deka Intimidator, bought one in February and its been great.
https://www.oreillyauto.com/detail/...36/battery/34rplt/4742697/2005/toyota/4runner
