Battery Dies when Door or Rear Hatch left open
Smurray
Is this normal? It's mostly for when I leave my rear hatch open when the car is off keys out of ignition. Sometimes it will happen if its left open for only 2 minutes. I've had it happen with doors too. Thing is the electricals turn on, but the car won't turn over unless it's jumped.
I'm electrically challenged. Is there an easy fix for this?
No it's not normal, sounds like your battery is bad, have it tested at any local auto parts store for free, make sure they do a "Load Test", also while you're there have them test the alternator as well.
Have the battery tested. Chain stores like Pep Boys and Advance Auto Parts should be able to test them at no charge.
The comment [MENTION=149207]AuSeeker[/MENTION] made about getting the alternator / charging system tested should be done as well... if that is contributing to problem, its only a matter of time until you ruin the replacement battery.
Even if all you did was measure the voltage with the engine running, should give you some indication if charge is even being put back into the battery.
It was replaced before I bought it 1.5 years ago. Any recommendations for batterys?
I just went with the Costco brand. I have a battery tender that I use on my vehicles to top them off every so often if they sit for a while or just as part of my vehicle maintenance.
charlesz
