BBQ/Smoking Meat
I'll have to look for Orange wood, thanks :)
Sent from my Nexus 5X using Tapatalk
I buy almost all of my smoking wood chunks (including orange) at Academy Sports. Also, their oak lump charcoal is the best I have found... better than BGE lump and much cheaper. Their hickory lump works wells but is sometimes too hot with plenty of fireworks.
My Masterbuilt smoker needs shavings or splinters and chips vs. chunks
I buy my smoking wood in the camping department at Big5, but limited variety.
I'll look on Amazon shortly
Academy also has the small chips in many varieties and several varieties of smoking pellets.
I only use "real wood" lump charcoal. Because lump made from plastic or other artificial wood is awful.[emoji6]
Today I tried the "snake method" of arranging coals in my Weber kettle - see the pics of how this works. The coals are arranged as a snake, 2 deep and 2 tall - around the circumference of the kettle. You light about 8 or 9 of them in a chimney and place them at the end of the snake. This causes a slow burn over the course of several hours. Toss a couple chunks of mesquite on top of the snake near the beginning of the burn.
I got this setup going and temps were maintaned from 240-260 for just nearly 4 hours.
Towards the end I took them out and finished them off in foil bathed in apple juice at 250F for 1 hour in my oven. I think this was a mistake because they turned out to be fairly dry. The meat wasn't falling off the bone as they were before. I think they were overdone. The flavor was awesome - it was just the texture and the moisture that needed work.
Anyways, still tweaking/experimenting with this. Hard to go wrong, really :)
240-260 is pretty hot for ribs, and with no moisture they will dry out.
Try lowering temp to about 225 and adding a water dish under the ribs, or crutch them at the 2 hour mark.
Have fun experimenting :thumb:
I had a water pan under them. Next time I'll try a shorter cook. I've done them before in a similar fashion and they were more moist.. I was thinking maybe I screwed them up in the oven.
I did this chicken last week. Used a Jerk rub, smoked with some walnut I had. Still struggle with chicken... specifically the skin. It looks great, but was tough. Not chewy, not crispy. Really couldn't eat skin. Meat was great though. Made some mashed potatoes and green beans with it. Was good, hated to waste the spices/skin though.
Any thoughts on skin? At this point, I wonder if I should peel back the skin where I can, put rub directly on the meat, then put skin back on and pin it with toothpicks to help keep it moist?
240-260 is too hot, especially if you're not spraying them or basting them with any type of fluid.
Hmm.. From what I was reading it seemed like anything under 300 would probably be fine. Maybe I just need to take them out an hour sooner. I wasn't spraying/basting them with anything... Just olive oil and a mesquite rub prior to "going in". Maintaining 225 in a Weber is gonna be tricky.. Hmm..
Edit: Come to think, it was around 240F or so for the first hour, then the temps slowly increased to 250-260 as the afternoon went on and the sun started shining on the kettle. When I started, it was in the shade. I'm pretty certain that has an effect.
johnnya
