Best bug/ rock deflector?
Scrubber3
A quick search turned up very little. Who makes the best bug/ rock deflector for the 5th gen? Last week on 95 my windshield took a hit from a decent rock. It's been repaired but I don't want to have to keep getting it fixed. Also, spring is here and we've had a very mild winter so the bugs are going to be awful.
Thanks in advance
Thanks in advance
Wondering the same thing
Bug deflectors won't help with rocks on your windshield. It's simply a drawback of the more vertical windshield. I've had 6 rock chips since mine was 6 months old.
What brand do you have? What is the difference between Weathertech and AVS?
Exactly. A rock screaming at your windshield will just punch through whatever weak air stream these deflectors create.
I have an AVS, but since it's the only one I have, I'm unable to compare it to other brands. It fits, and I guess it works.
I, too, did a search for deflectors and found 14 posts full of different experiences and discussions.
Yep a rock on a mission won't care what's moving air around your windshield.
IMG_20170228_134009221_zpsqhyzlqab.jpg~original
That's not a vertical windshield. My FJ had. A vertical windshield!
But you're correct on the bug shield being limited in this regard. But your T4R looks good with the one you have.
Thanks in advance
I've replaced two 4Runner windshields and had 1 rock chip repaired since 2013. It's the price you pay to play.... These windshields are like rock magnets. Keep back from semis is the only advice I can give. Bug deflectors will not help. However glass replacement on your insurance policy will.
Agree with all the comments above. Probably the worst windshield I've ever had for rock chips/cracks.
For bug deflectors I have the AVS - you can't beat the price and shipping through amazon. Personally, I think the OEM looks better but it is definitely not worth the price!
bug shield are good for two things:
1. Draining your wallet
2. making it harder to wash the hood
Draining your wallet, maybe. You're saving money from repairing hood rock chips.
Harder to wash I don't think so - the AVS protector is raised off the hood to the point where you can definitely spray under it.
I'm waiting for this one to hit the market. 1400 miles on my '16 TE and already had a rock smack the hood. Damaged the paint protection film. Can't tell if it dug into paint...
Sent from my SM-G930V using Tapatalk
I have as many rock chips on other parts of my hood and A pillars as I have on the leading edge of my hood. Touch up paint costs $10.
Deflectors protect the few inches of paint immediately behind it from rock chips. That's all they do. They do not keep bugs off of the windshield. They are a cosmetic mod.
The problem you can run into with running a deflector is this: Crap (moisture, dirt, salt, sand, pieces of leaves, etc) can get washed in there and you don't know it. If you already had a chip then that crap will cause that chip to rust. I have seen many cases of bug deflectors being removed after several years to find that the hood has severe rust around the leading edge of the hood. You can't get it out unless you periodically remove the deflector and clean behind it. If you do that then good for you. Your few inches of hood will be protected from rock chips. Otherwise? Meh. Fashion only.
When I took my stock rack off last week I found three rock chips on the roof!
:faint:
Yep. The leading edge of the roof right around the windshield, the side mirrors, the A pillars, the leading edges of the hood scoop and the hood creases are where a lot of rock chips happen. That's in addition to the front bumper cover of course.
Touch up paint application tip:
The touch up brush in the OEM touch up paint bottles usually are too big for small chips and you end up globbing too much paint into the chipped area. When I am touching up a small chip, this is what I do:
1. Clean area with rubbing alcohol and wipe off
2. Take a small piece of soft paper, like toilet or tissue paper and twist it up where one end comes to a hard point. Alternative is using a paper match but those are getting harder to come by nowadays.
3. Use the touch up brush and a piece of metal or glass (empty beer bottles are somehow always in the trash at my house) and brush a bit of paint onto the glass.
4. Now take that twisted tip of paper and touch it on the still wet paint on the bottle...
5. Touch the tip of paper to the chipped area. The paint will wick into the chip, filling it nicely without globbing.
Takes all of 30 seconds.
I've found that it helps with chips on the hood. I haven't had any since I've installed it. Personal taste, but I really like the looks of it on the 4Runner which is the main reason I have it. It doesn't do anything for bugs or rocks on a windshield though.
I run AVS and came from a road trip..
Did not see a single bug touch the hood but it deflected towards my windshield but then again its spring everyone is alive lmao..
It is a cosmetic add on and thats really it.. I think rocks will just hit your windshield regardless and no aerodynamic mod can eliminate the velocity and weight of a rock lmao.. Maybe a prius? Idk lmao :artist2:
I'm using the AVS. I'll say I've noticed less bug splatter. They're still there though.
Won't say it'll help with rocks/pebbles because I just had one hit my windshield on Monday going to work.
On my 98 Explorer, the bug shield lip curled upwards. Huge help. Rarely saw any mess on the windshield.
Personally I like the look of it though.
EnviroHokie
