Best Source For 2020 TRD Pro (Heritage) Grille
Hi,
I have a question for those of you who have purchased the grille from 4runnerlifestyle.com and have a 20/21 TRD Off Road Premium. Did you need to cut or trim anything or did it fit perfectly? Because on their website it says only compatible for 21 TRD Off Road but does not fit TRD Off Road Premium model? What's the difference don't they both have TSS?
I emailed 4Runnerlifestyle to ask the about compatibility with the TRD ORP, this is what I got back.
“So the only thing that changes is some times the clips are different but we have seen plenty of people have that exact 4runner and it works with no issues so it is super weird!”
Are there any better deals on the '20 TRD Pro (Heritage) Grille parts?
Below are a few links to the proper '20 part numbers along with discounted prices; however, there has to be better deals out there:
Garnish Front Bumper PZ323-35058 | Boch Toyota South
Grille Radiator Up PZ327-35056 | Boch Toyota South
The below post from [MENTION=407981]snowpeak[/MENTION] on another thread includes another location w/ similar prices and helpful info on this application:
would these work on the earlier models 2017?
Finally getting around to posting my grille install from Mcgeorge Toyota. Highly recommend, as the quality and fit were OEM.
I bought mine from McGeorge Toyota online parts. Not sure what the current price is now but I believe it was 35% off list and I had the parts within a week.
Stick with the OEM. They fit perfectly. You won’t have to dremel around the sensor like others have with the knock off garnish.
Which part number was this? Is the one for the sensors with the notch cut out
The upper grill is completely reconfigured. This applies to a 2018 Pro grille installed on a 2020 ORP. Only 4 of the 6 screws are in the same place, and the support bracket that ties back to the radiator support is entirely different. I have it installed, and it "works", but I also have the correct part on order so as to make it right. I'll take photos of the two when the correct part arrives and I swap it out.
Hey erikjon, what is this 'correct part' you speak of, did you get it, and can you share photos?
I'm looking to upgrade the grille on my 2022 ORP w/ TSS + Multi-terrain camera using parts PZ327-35056 (4Runner TRD Upper Grille mesh) & PZ323-35056 (Toyota script Garnish Front Bumper) however McGeorge emailed me to say that PZ323-35056 is for 2019 and earlier models only.
Just looking to make sure I get the right parts.
I'm in the same boat and doing the same research ('22 ORP with TSS and MTM). I think you're actually on the right track with the PZ323-35056 (2014-2019) garnish.
I've come to the conclusion that since our MTM-equipped ORPs do not have the high-mounted TSS sensor (2020-21 and '22 w/o MTM) I need a garnish that does not have the sensor cutout, which means the '14-'19 garnish should fit better. (Provided nothing else has changed between 2019 and 2020+ -- like overall dimensions, etc.)
So...I think the way to go is:
PZ323-35056 – GARNISH, FR BUMPER (2014-2019)
PZ327-35056 – GRILLE, RADIATOR, UPPER (2020+)
I can't say definitively this is the way to go, as I haven't actually acquired and installed anything yet (prices for the OEM products are kinda nutty), but it's making sense to me right now, based on what I see on my rig and in photos of the various garnish versions.
(This said, the garnish with the cutout for the high-mounted TSS sensor is probably fine, too, as the cutout will probably be unnoticeable.)
Anyway, my $0.02. Good luck!
The 2020+ garnish is tad cheaper and the only difference is a small lip cut out which isnt noticeable from head on view. The grille portion has a few different clips and can be fitted but more difficult.
I opt'ed to go with PZ323-35058 and PZ327-35056 for my 2022 ORP with TSS and MTM...well see how it goes! The lip is barely noticeable and I would rather not have to mod the parts if needed. Parts just shipped today, should have install completed in coming weeks.
Any updates? Did it fit? I'm looking to order the same for my 22 ORP
Shutup and take my money!
Super quick shipping from McGeorge Toyota, friendly parts department too, cheaper pricing than my local dealer, highly recommend them!
Install was fun, took me and the kids about an hour to complete. Take your time and don't pull too hard as there are clips than can bust if not careful.
I used parts PZ323-35058 & PZ327-35056. The TSS notch is barely noticeable and not a concern at all (see pics).
Love the way it turned out!
delislerebecca
