Ripper238
Senior Member
Came across this video on how KDSS works. Very detailed and really makes me happy i got it.
https://www.youtube.com/watch?v=m3BnLLwbScA
2021 Toyota 4Runner TRD Off-Road Suspension Walkaround: Why I Bought The KDSS Stabilizer Bar System - YouTube
he does a great job explaining, good video. he needs to make a video on the XREAS and ATRAC now. although there are a couple good ones for ATRAC, I haven't seen a detailed XREAS one like this though. KDSS, XREAS and ATRAC seem to be common themed questions for prospective buyers
It is because of this video and understanding what KDSS does along with knowing I am not going to do a wild suspension upgrade, I went with KDSS on my order!
Best part is you can still do a ~2" lift with KDSS if you really wanted to.
Great explanation, especially the bike thing. Thanks for sharing. Love having KDSS on my daily. 2.4" lift with 33s and it drives like a dream.
I've read a lot of posts about KDSS trying to understand what it feels like on the road. It always seems to come down to something like, "It feels better" or "It drives better."
I'm trying to understand specifically how it feels or drives better on the road, not off road.
The video posted goes over exactly what it does on the road.
Primarily it's a super stiff roll stabilizing bar, so when you pull lateral G's the vehicle stays flat and level (relative to a non-KDSS vehicle of the same make/model/weight/lift/tires/etc.) instead of leaning at an angle. Basically it feels confident when in mountain twisties. It's still not a sports car by any means, but it is stiff and stable in the turns.
A TRD Pro doesn't have KDSS; so what is it like in lateral Gs? Or does it have a suspension that compensates for no KDSS?
This may be the best place to ask this… I’ve read conflicting things on here before. When does the system go “limp”? I think it’s below 12mph, but I’ve heard some say it must be in 4lo but others say no. I’ve never seen conformation. Right now, sitting in my drive way, is it limp? Allowing the pistons to easily move up and down?
Thanks for the reference. Jetboy always knows his stuff. Now, I only know enough about this system to be dangerous… If the system is open all the time, then what purpose do the valves on the controller serve when performing lift installs? Or is that essentially just combining a “recal” of the system at the same time of lift install?
Here’s why I’m asking. I’m installing my Dobinsons lift on Thursday (finally…) and I want it to be as loose as possible to see if I can get it in without actually disconnecting the sway bars. Many seem to accomplish this… I don’t want to open the valve bolts because my driveway is not level and I don’t want to open them there. Thanks.
While the system is 'open/relaxed' at low speeds etc, the front and rear piston are still hydraulically connected. If you were to lift the front driver and rear passenger at the same time, then the system would be balanced, but if you lift both driver side tires, the system will develop anti-roll stiffness regardless of the valve positioning. So there are kind of multiple combinations of electronics and natural loads that allow KDSS to operate.
I installed my Eibach 2.0 coilovers without opening the valves. I just used a Jack to compress it while I worked on the opposite side and vice versa. It really wasn’t that hard to do imo. Just have multiple jacks that go high enough and you’ll be fine.
