BFG KO2 vs Nitto Terra Grappler G2 vs Falken Wildpeak AT3W
I didn't see a mileage hit really. However, getting them balanced and keeping them balanced has proven to be a real pain. I think I'll be looking elsewhere next time.
I would hope that the extra 6 lbs per tire doesn't have cause a significant drop in MPG. I've looked at some other lighter tires like the Toyo OC ATII but they seem to be similar to the stock Dunlop AT20 that I already have.
I've been using BFG ATs for over 20 years. I've never experienced the wet weather issues that others have experienced. I put stock sized BFG ATs load range C on my 4Runner. I could hardly wait to get those noisy P rated factory tires off. I'm getting over 18 mpg for normal city driving. I'll get around 20 mpg on the highway.
I had E-loads on my F-150 and they were terrible in the rain. I can't find any reason why the C would be any better but I wish that were true. Falken uses the silicon compound in the SL load but not the E and that is supposed to be the reason why the SL handles wet roads better. They clearly state that the E loads won't handle slick roads quite as well. I have seen nothing about the silicon compound in the KO2s in any load range.
This video explains the difference between sl and E load in the Falkens at the 2:00 mark. I am not getting the mileage you get now btw. about 17 in the city. Maybe 20 on the hwy if I take it easy
YouTube
How many miles do you have on your KO2s? Mine started to suffer after about 10k. The rubber compound just seemed to get really hard.
pulled the trigger on wildpeaks in stock size for 2016 4runner with mild lift, it was a HARD decision and about drove myself crazy over whether to get them or not with all the talk of out of round- balancing issues. IMO they are the best looking with K02s a close second. Getting them installed tomorrow at discount tire and hope to not regret it ...
Yes, I am getting to 30 as well.
I have got no balancing issues on my P-metric but I, too, am exploring other options. I do not like it that I spend only 10,000 miles at 10/32nds or higher. I may just keep buying Wildpeaks as they are so cheap but it is all TBD at this point.
Seems to be a pretty common theme that at roughly 25-30k you should expect any AT tire to start getting loud. I had the same issue with my KO2s and others have noted the same. Guess it's just something you have to accept. Cost is more of a factor if you switch up at 30k.
Just reading through this thread overwhelmed that i have to start over researching for the best tire. It took me 10+ years to find the 2 best tires for cars. Now i have to start all over and its going to drive me nuts.
Ill probably do a winter set and a summer set of tires on 2 sets of rims i have. But that may not be the solution like it was for my car (set of summer set of winter).
When i get closer to needing new tires ill check in with the community first.
I run 265/70 K02s C on rims and a have a second set of rims for winter for 265/70 P rated Michellin alpines.
Purchased the WildPeaks AT3Ws and have no complaints. Similar to yourself majority of my driving is on road. Also the price point of the WildPeaks are better than majority of the tires out there.
YouTube
I would get over 50,000 miles on several sets of load range E tires on my 2500HD diesel. Before that I used load range C on that 2500HD and 1500s that I've owned over the years with the same results. I never had wet weather issues with any of them.
Let us know how it goes!
I don't expect any AT tire to last me more than 30k. But I would rather not be looking over my shoulder in the desert, or wherever else sharp rocks abound, over half of that mileage. I can realistically expect 30-32,000 from KO2s without that particular worry but I like the Wildpeaks much better in all other respects. Will see. Will be monitoring reviews of the brand new Destination XT.
I don't expect any AT tire to last me more than 30k...
I currently have Nitto TG2 (stock size, P rated) with about 45K on them, still very quiet, smooth and plenty thread left. 4Runner is used for hunting trips in Texas (mud\rocks\thorns), numerous family skis trips, trips to the west and Rockies with moderate off-road trails-including Moab and it is my DD… no issues… the only negative thing is the wet traction got bad as they got older... hence looking to replace them soon… and at this point, I am 90% set on WildPeaks AT3Ws.
Based on all comments I see here my only two concerns with AT3Ws are possible balance issue and their weight (negative impact on MPG and performance).
bilstein 5100s @ 1.75 front, rear no lift 265/70/17 falken wildpeaks at3w - TRD wheels
shoutout to discount tire, they were fast getting the tires in and at the last minute I was on the fence about the wildpeaks and wanted to compare them to cooper discovery tires and they mounted one and put it on the 4runner for me to see and in the end the wildpeaks price and looks won me over...so far KNOCK ON WOOD absolutely no front end shimmy or balance issues...ride seems smoother than old tires with no added road noise
I purchased my AT3's about 9 months ago and they've been fantastic! They are close to $300 less than the KO2's and perform better in wet and snow. I also had the Nitto's on my FJ which I enjoyed, but they got loud at their half life. I would recommend the AT3's to anyone!
I think some people take individual cases of issues as the norm.
Both the Wildpeak AT3W and the Discoverer AT3 are top-tier tires. Neither is perfect. The AT3 is not the strongest AT and the Wildpeak has quality control issues here and there. Most people won't have AT3 punctures or Wildpeak balance issues. The KO2 is also a top tire but for a specific reason (strength in very rough terrain).
Looks great! I am not sure if black color of your truck makes the difference, but considering you have 1.75 lift those stock size tires still feels the wheel well really nicely!!
I agree. The stock size looks perfect with that lift. Great looking rig.
The 265 Wildpeak has 9 inches of tread. This is on 7.5 wheel but I don't think it matters because the tire unmounted is still 8.9". Section width is different and wheel size matters there.
9" is A LOT for a 265. The stock tire is 8.3" wide in the tread area and most 265s are between 8.3 and 8.8 wide.
In fact, there are 275s that are narrower than a 265 Widlpeak and 285s that are barely wider. It all depends on the specific tire.
On the other end, this also makes comparisons vs 255 exaggerated. Whereas a normal 265 would be 0.5" plus minus a little bit wider than a 255, the P265 Wildpeak is more than 1.25" wider than the narrowest 255s!
So, nothing like the 10 mm difference on either end.
Reading through the reviews of these tires on discount tire is interesting to me, because some of the scores contradict what has been shared here and elsewhere.
BFG KO2 112S / Load Range C: 4.7/5
Falken Wildpeak AT3W 115t SL: 4.6/5
Nitto Terra Grappler G2 115T SL: 4.6/5
For example, all have the same rating for "ride comfort."
KO2 has a 4.5 rating for ride noise, and the AT3W and G2 have a 4.2 rating, but they're both passenger tires, so I would think they should be quieter?
KO2 also has a higher wet traction rating than the G2, but AT3W is best.
I guess I'm really most interested to know what type of change I'm going to see in ride quality and comfort going from a BFG KO2 Load range C to a Falken Wildpeak AT3W passenger tire.
Has anyone here gone from:
P-Rated Terra Grappler G2 to C-Rated KO2?
or
C-rated KO2 to P-rated Terra Grappler G2?
Trying to get a feel for how ride quality differs between the two. I am currently leaning a bit more towards the TG G2 because of weight. People complain about wet traction with the TG G2, but they also complain about it with the KO2 and I've never had a problem. I think the full time 4X4 helps (Limited).
Cpn2mss
