Making them is very easy compared to trying to use pre-made cables that don't fit perfect, or is overly expensive. Factory is 8 GA on the charge wire and engine / frame ground and 10 GA on the body ground I think.
so #4 on all cables for upgrade; grounds, starter, etc? i found someone that makes them to order, any length, gauge, terminals, etc. for the ones that have made them themselves, how much was spent on supplies and from where?
No need to replace the sstarter cable unless yours is corroded, the main goal is to help the alternator charge effectively and strengthen the grounds in the system.
