Biggest tire size safe on stock setup?
hondafmx1000
i was just wondering, i want to put some nice meaty tires on my t4r but im not quite sure if im gonna have the money to lift for a while, i feel like i dont do enough wheeling to justify lifting it anyways, later in the year ill do some trails when im hunting but its my daily driver, any advice/ suggestions maybe a spacer lift is sufficient? let me know some feedback, im curious what you guys say.
265/75/16. (aka 32's). Don't mess with a spacer lift. Coils or don't bother. Plenty of people that don't lift their 4Runners, mostly because it's their DD.
My .02 - take your running boards off and throw on a set of 265/75 DuraTracs. You'll be amazed at the difference in appearance!
Thanks guys, i really appreciate it, the running boards are definitely on my to do list, i hate them, but my girlfriend uses them lol, and 265 sounds good to me, im thinkin some black slotted rims and some nice tires with the tax return, maybe some decent speakers too if i can afford it, maybe a roof rack too, and while were at it, some new tint, and then a supercharger. and then.............
i need a better job!! lol
Bigger tires and no running boards do wonders for appearances.
P1050280.jpg~original
My .02: I would check out the tundra/ LC lift before I went too crazy spending money on "acccesories". If ya think you want to lift it for sure, that is. Doesn't cost that much.
I was searching for the max tire size on stock suspension and found this thread.
I have one quick question:
WHAT IS THE RECOMMENDED TIRE PRESSURE FOR 32" AKA 265/75/r16 ?
ALSO 32 PSI LIKE FOR STOCK SIZED ONES OR MORE?
THANKS.
THANKS.
I run 32 on the back and 35 on the front. That's with C rated duratracs.
THANKS.
Generally, the bigger the tire the lower the pressure.
The Load Range rating will affect how much PSI you should be running in your tires. It's not necessarily just about the size.
I run 40PSI in my Load Range E 265/75R16 M/T's
32PSI is the recommended pressure for 16" 265/70/16
And it's a good starting point for the 265/75. For tire wear and fuel economy reasons you want the most air you can get without causing the tire to crown (and wear out the center of the tread) The converse is higher pressures are less comfortable and offer less traction.
The optimal tire size for a stock truck is 285/40/24. :D
[MENTION=116387]Unner[/MENTION] [MENTION=116467]Rock_Rat[/MENTION]
seltzernator
