Bike rack as tire carrier?
p00flakes
Member
Hi all,
Apologies if it has been asked before, but has anyone tried to use/modify a sturdy bicycle rack (eg. yakima etc) as a tire carrier? The 4-bike ones should be able to manage the weight of a tire and rim (approx. 70lbs in my case). I know that there are swing out racks as well. May be a cheap option to the tire carrier choices that we currently have? Or tell me why it won't work? TIA!
P.
If you have a spare hanging rack, there is no reason is shouldn't work. Otherwise why not just buy a cheaper one?
You could likely just drill a hole through the upright for a hitch pin to act as a positive stop and then mount one of those universal clamp-style spare carriers for trailers..
Yes, my main thought is to actually get a side swinging adapter like this:
Attention Required! | Cloudflare
and then adding a spare tire adapter like this:
Amazon.com: CURT 31006 24-Inch High Trailer Hitch Spare Tire Mount for 2-inch Receiver: Automotive
Total cost 329+110= $440.
I was originally looking at the Wilco hitchgate solo, but it's about $895 for a swinging one:
Hitchgate™ Solo | WilcoOffroad.com
Just wondering if there's something that I missed, or reason(s) to get the Solo instead?
P.
Yeah I was thinking more of a DIY approach if you already had an existing bike rack. Kuat makes nice stuff but you could likely save some cost going with a vertical swing rather than horizontal.
something like this:
Ah gotcha. I don't actually have a bike rack at the moment. I have considered the vertical swing as well, but would probably get more use out of the horizontal swing (and not have to drop/lift the tire every time I wanted to open the rear hatch)...
P
Hi all,
P.
I was going to build one but decided I wanted a swing out and didn't want to spend the time to fab one. 8 weeks later still waiting, kinda wishing I had just made my own. Anyways, here is another option for you...
Curt spare tire carrier paired with a fold down trailer hitch. These can be obtained from Amazon or E Trailer for short money. Some minor mod is necessary. Be warned it will rattle a bit unless you mod id further, but so would a bike rack.
EDIT: just saw your above post using the Curt and the swing out. That slick too. Let us know what up doing.
Any updates? Thinking about the same project instead of buying an 700+ swing out tire carrier? And were you able to add table or gas can carrier?
