Bilstein 5100's and Daystars with FJ Coils
bradentyrer
Hey
I need some advice regarding my suspension, '03 SR5. I'm doing the FJ swap and am gonna put in Bilstein 5100's up front. I currently am running original springs and shocks all around with the Daystar Budget Boost up front. 170,000 and the shocks and struts are finally going (I just bought it a few months ago).
My question is that once I put in my new springs and shocks in the back, I want to go with the Daystar 1.5 lift in the back. Can I keep the budget boost up front and change the setting on the 5100's? If so, what setting?
You could do what you said in the rear and dump the budget boost up front and just set the 5100's to max. That's what I did.
How level are you sitting with that setup - the Daystar 1.5 and the Bilsteins set all the way up? And what kind of wear are you getting on other suspension components? Thanks
Here are my measurements the day after I did it to the fender:
Before lift:
RF = 32 ¼” LF = 32 ½ “ RR = 34 ¼” LR = 35”
After lift (pre-alignment):
RF = 36 ¼” LF = 36 ½” RR = 36 ¾” LR = 37 ½”
I have not measured it since alignment and time for it to settle, but I have not noticed any issues with the suspension nor have I noticed any leaks from anything.
Here are before and after pics:
Jhunt
