bilstein c475 height adjustables
alex56
hey, i bought these shocks, but i lost the papers that go with them for the height increments that you can lift by moving th spring clip :0
can anyone tell me the lift increments on these shocks
thanks!
The ride heights in the manual are approx. It can Be plus 0.5" base on may actual installations from FJC and 4th Gen 4Runners. So, by adjusting it to say 1.75" it can actually give you 2.25".:)
is yours are ay 1.75 what did you get out of it you think?
right now i have stock front shocks with a 3" spacer and ome 884 coils
i think im going to just put these shocks down at the lowest setting and run my 884 and coil spacer should give little over 3" no?
alex56,
I have no idea when combined with OME and Spacers LOL!, but the stock setting of the shocks which is the first notch/grove will give you precisely stock height. Should there be a difference, its because your suspension have already settled. So you will still get the same lift as you have now.
Your Setup : Factory Shocks(0" lift) + OME 884 and Spacer(3"lift) = 3" total lift
Plan Setup : Bilstein set to Factory(0" lift) + OME 884 and Spacer(3" lift) = 3" total lift.
How about setting it to .85" and install just the OME springs. It might give you a little over 3". But Bilstein warned against installing it with aftermarket coils and not setting to minimum height...I don't think there is a problem.
Here is a slightly different installation :naughty:
http://www.toyota-4runner.org/4th-g...-daystar-1-5-rear-spacers-installed-pics.html
