BL Needed? 3" OME with 275/70R17 BFG AT KO & Spidertrax
Beertinted
Do I need a 1", 1/2" or no body lift to minimize rubbing and allow chains when installing BFG AT KO 275/70R17 on a 2006 SR5 V6 with an OME 3" lift, 1.25" Spidertrax, LR UCA's and stock 17" wheels?
I'd like to minimize (or eliminate) trimming. I wheel on Tahoe rocks and snow.
Thanks!
I have 275/70R17 with ToyTec Ultimate lift + spidertrax + light racing UCAs and I didn't need a body lift. I rubbed a bit on the wheel well liner but you can push that back, I also had to remove mudflaps as well. but you dont need a body lift to "avoid" the rubbing
Thanks!
You should clear fine with out a Body Lift. Unless your running in icy snow, I would just lower the tire pressure a bit and avoid using the chains.
