black rims white rig
sl0annuggets
i dont have it yet but i have the black rims and tires off my tacoma... will it fit? They are 31 10.5 15
its a 2000 4wd sr5 4cyl 5spd
Will it look ridiculous? if i had photoshop skills id do it up but i am hopeless with it.
Shouldn't look ridiculous in my opinion, but I LOVE black wheels! Where you may run into a problem is with your 15" wheels. If your 4Runner came stock with 16" rims then the 15's probably won't fit. Check your driver's door jamb for a sticker that should have your factory tire size.
I know me too.. i have them left over from my tacoma... here she is ... she is on her last few weeks of life (frame buyback)
Rims aren't exactly black, but they are dark, and close to stock size...
i know it says they do but its only for certain brake packages.... im just gonna have to hope and then trade or sell if they dont work
I guess I just read the description for the Tacomas.
*NOTE: OUR 15" WHEELS ARE DESIGNED SO THEY WILL FIT ON A 95-04 16" FACTORY EQUIPPED TACOMA! NOW YOU CAN RUN 15" TIRES ON YOUR 16" EQUIPPED TACOMA. WE'VE HEARD OF A RARE FACTORY OPTION IN 2004 CALLED "VSC"- IF YOUR 2004 TACOMA HAS THIS OPTION YOU NEED TO STAY WITH 16" WHEELS OR BIGGER.
4Runner:
*The 15" wheels are for 95-02 4Runner's that do not have the larger front brake package associated with 16" factory equipped wheel packages. One way to determine which brake package your 96-02 4Runner came with is to measure the diameter of the front brake rotors; the standard brake package uses rotors that are approx 11-5/8" in diameter and the optional brake package usually related to the 16" factory wheel package and/or the SR5 or Limited Package (but not always!..) has a diameter of approx 12.5".
One sure way to figure out if you do have the bigger rotors is to look at your calipers, and if they have S13WM stamped on them, you have the bigger rotors.
go to www.oktire.com, then go to 2 ways to shop , -check em' out on your ride then go into ''Enter Next Wheels Online''
and then it will take you to a seperate screen where you can find your make and model and get a tire size lift kit and the rims you want and see generally what it will look like! hope that helps
allcarhistory
