Bleeding brakes 02 t4r? Sliding gas tank over?
D Farms
I need to install the rear soft brake lines on an 02, I haven't found guide that is specific for the 01-02 so I was wondering what the different procedures are. Also I've heard that the 01-02 has some sort of brake booster that can be used to make the bleeding process easier, is that true?
On a side note after my lift the drive shaft runs right into the gas tank skid, I've heard you can slide the gas tank over a few inches to give the drive shaft room to rotate. Has anyone done this with the tank?
lilliagarcia
