Blower Motor Intermittently Failing to Run
StealthyBlagga
A couple of times a year, the blower on my 2008 V6 (w/ 105k miles) fails to run. This is VERY intermittent. Sometimes the blower will spontaneously start running after a few minutes driving, sometimes switching it off then on again will start it, sometimes shutting the engine off then on again starts it, but I am not really convinced any of these steps is actually telling me much (may be just coincidence).
Yesterday it would not run at all, even after fiddling with the switch and stop/starting the ignition. I drove for over an hour with multiple stops and the thing would not blow. I got up this morning to start troubleshooting, and - wouldn't you know it - it started blowing just fine. Multiple on/off/engine restarts etc., it is running just fine every time now.
I live in AZ and it is around 80-90F this time of year, so definitely NOT freezing up, but the blower does run almost all the time. I guess there are three likely suspects: relay, motor connector, motor (brushes etc.). Any suggestions as to which could be causing something so intermittent? I was thinking of eliminating the relay by switching it with the dome light relay (looks the same)... any other ideas?
H.Sikina
