Body Mount Chop plates.
After all the front end work has settled in, there is still some slight rubbing on the right side.
Both sides were rubbing the "body mount bump" on the mud flaps. Removed those and the left side clears.
Time to get the angle grinder to remove and smooth the shiny spot.
Sent from my SM-S908U using Tapatalk
No, they are not created equal. I haven’t encountered any that are the same thickness as the Toyota frame - usually the plates are too thick, which makes it a PITA to weld on, as you need higher temp to weld thicker steel.
Ambrose67
