bolt pattern ? which do i have
06sr5
I found a nice set of wheel but I am confused on the bolt pattern. 2006 4runner sr5. Is it 6x5.5 which in metric is 6x135mm bore size 108mm. or 6x139.7mm I have done a serch but I am not 100% sure. looking At incubus alloy 518-helio It has a limited wheel look. I would show the wheel but I cant figure out how to post pic,www.incubusalloys.com rwd section.
5.5" = 139mm
so it'll be a 6x5.5 or a 6x139
You should also verify that your new rims will be compatible with the TPMS sensors for the wheels.
Is there any factory Toyota truck rims that would fit the 4R that are 8" ? or a truck rim with a different offset to push them out a little further ?
I don't know why, but the '07 Tundra is a 5-lug, 5x150 I think. Land Cruiser and LX470 are also 5-lug. The rest, GX, Tacoma, 4R, FJC and Sequoia are 6-lug.
wow, that's weird, given that the tundra is big and has more power
My friends Land Cruiser is 6 on 5.5
Strange...
Older Tundras were 6 bolt. New one has gone with 5 on a larger diameter. Must be also using larger diameter bolts. Why not go with 6 on larger diameter???
Now that I think about it, the previous gen, 1990-97?? were 6-lug. The current gen, I think 98+, are 5-lug. I remember seeing the current gen by my house, I stopped and walked back to check to see if it was actually 5-lugs, sure enough, it was.
It's just strange that the bigger SUV and truck has 5-lugs and the smaller siblings have 6-lugs.
DanielShawSZ
