Bolt size for Two side arms with oem Skids
mastee
Hi,
I had picked up oem skid set from a member here. There is a front and middle plate, which I believe need M8x1.25x25mm and I need 6 or 8 of them.
Plus there are two side arms about 12 inches long, I am not sure where these bolt on. Anyone knows what size bolts I would need, will post pics shortly.
Hi,
Plus there are two side arms about a 12 inches long, I am not sure where these bolt on. Anyone knows what size bolts I would need, will post pics shortly.
These onese
Sent from my SM-N910V using Tapatalk
I've replaced the skid bolts, as well as rear swaybar bracket bolts and some brake line bracket bolts with 95735A421 from McMaster. One bag of 25 was a few bucks and I am on a mission to replace every rusty bolt I take off for any reason.
The long brackets are I believe these, the bolts are the same size, M8x1.25, but what length I don't know (sorry not going to take apart my car just to find out :) )
Thanks a bunch for the picture this is exactly what I needed, I think length would not be an issue since they will be screwed into the frame.
Good idea on replacing the rusty bolts, my truck came from connecticut so there is some rust like yours but except the front rad support its not bad
For some reason the rust looks worse on photos than in person, it's mostly just surface rust. There are some worse spots in the rear though. I have other things to work on atm but I'll get to them hopefully before winter.
charlesz
