Boss Adjustable Coilovers 1-3"
I've never had any squeaks from mine. Did you replace / remove any other parts during the install?
I am running this lift on my FJ and also have no squeak. Did you replace the UCA's at the same time?
My buddy works at that shop so he gives me a fat discount and they have a couple of techs that really know off-road stuff from taking with them. The sound actually sounds like it is coming from the UCAs. Does anyone know if that sounds like it could be the issue? Maybe bad bushings?
Mine did not squeak and I did not change UCA's. Did they put the sway bar spacers in? The only folks that developed a noise had rubbing from not putting those in, but was not described as a squeak.
I too have the boss coilovers and have a little squeak action going on... and I believe this is the reason why. Going to install the sway bay spacers and radiator brackets when I get the chance.:redbrick:
It Was The Sway Bar!
Hey guys, I took it back to Sears and my buddy checked it out. It really is the sway bar rubbing up against the coil every so slightly. Where can I get these bushings and or a new sway bar to extend it away from the coil? Is it going to be extensive on labor to put in? Because maybe I can do it myself depending on time constraints.
Toytec should have included the spacers with your kit. There should be 4 spacers total. 2 on the sway bar and 2 on the radiator support bracket. I would check the boxes to see if they are hiding in there. If not, call toytec. Installing the spacers is really not hard at all. Just follow the directions.
Dont shave the spring, get the spacers as commented above if you dont have them call toytec.
[MENTION=106490]TheJimboTron[/MENTION] you can put them in yourself, not hard, glad you figured it out so quickly and they did not shave the spring!
Problem Averted
Houston, we do not have a problem! Got things fixed. Turns out the spacers and blocks fell out of the box and no one noticed since they were in my cargo hold. Everything is installed and no more squeak. The sway bar was rubbing up against the coil. Thanks for the help guys! I would have never known about the spacers of it wasn't mentioned.
Laredotx
