BOSS lift pics/measurement
WEAK_E90
I am starting to look around for new suspension lifts and from the beginning i should have went coilovers to have adjustability in front.
Right now im on 5100 all around, OME (700lb) front and toytec 2.0 rear (with some 10mm discs to help driver side lean).
My measurements are hub to fender:
Front: 23" Rear 25"
With the boss kit ive done lots of searches and asked a lot of questions to people who have it - i cant go through every build page but for the ones who have it in your signature chances are i might have asked.
What are the boss measurements? I read a lot of 22"F/25R"? But i also read peoples whos are 24"F/25"R... these im guessing your adjusting (even though it says not to go over 3" would would put you at 22".... due to CV angles... which yes I am over to i guess :yo:)
Doe anyone have pictures of your BOSS lifts? Trying to decide if I should just buy new 5100 shocks... and add a small spacer in the front. Or buy a boss lift and risk the same rake angle i have which is why I am really thinking about changing... Id like to be 1" difference front to back but above 23" to make room for bigger 295s (yes i understand trimming is mostly what it takes to fit these but a higher lift will help).
Thanks in advance!
Google searches i have read 1st page of: t4r boss lift, boss lift 5th gen 4runner, boss lift 4runner, boss lift measurements, boss lift 4runner (images), searched instagram #toytecboss
wayblom
