Boudin's 01>99>97 3rd Gen dailys
Boudin
Day 1 ( August 2016 )
September 2017:
2001 Limited 4wd
Millineum Silver Metallic
Purchased August 2016 with 161k miles
1 owner with complete dealer service history including recent timing belt
Mods list:
Trail edition wheels
Cooper AT3 265/70r17
Bilstein t4r 5100s, second perch
Monroe top hats
Moog Coils Springs (99 rears)
Wheelers off road shock upper bushing kit
Daystar 1.5" rear spring spacer
1.5" wheel spacers (hubcentric/lug centric)
Depo clear corners and turn signals
MJT Grille
20% window tint
Led drl/switchbacks under filler panels
LED interior light panels, corner parking lights, reverse lights
Led Cubes mounted to rear bumper for reverse light
Morimoto Modpod drl switchbacks in place of Oem fog lights
Tacoma style 4x4 mud flap decals
HID retrofit, Morimoto mini d2s 4.0
Plastidip'd wheels Obsidian Black Pearl
Maintenence
OEM LBJs
Moog tie rods
AC delco sway bar endings f/r
Prothane sway bar, shock and Steering rack bushings
Centric rotors and hawk LTS pads
Centric drums
Wagner ThermoQuiet rear shoes
Cleaned MAF and TB
Bosch Air filter
Upstream denso air/fuel sensor
Diff/t case oils to Mobil 1
Day 1
First up was polishing the paint, removed running boards
Next was a $100 craigslist score Trail edition wheels, and new Cooper At3 in 265/70/17
Moog 99 tall springs to fix the sagging rear..
Plastidipd all the gold emblems in Hyper Graphite Black
Bilstein 5100s T4R, OEM LBJs, tie rods, sway bar endings, poly sway bar bushings, Moog front springs
Bilsteins set at second perch from bottom.
It had a slight Baja stance so I put on a Daystar 1.5" spacer in the rear to level it out
Added 1.5" Wheels spacers
Color matched the grille and added clear corners and turn signals
Added drls into the filler panels and led backup cubes
Morimoto Modpods in the fog location
https://youtu.be/S4nxgmBL8eY
Tacoma style mud flap decals
4 red slim led light bars with a flash module mounted on top the hitch.
https://youtu.be/gAMdtpQp8rk
Here's how she sits as of August 2017
Sent from my SM-G930V using Tapatalk
Future mods:
Burtman rear spoiler
Valve cover gaskets
Radiator and external trans cooler
Plugs and wires
Replace exhaust ( Gibson or Walker)
Send off climate control module
Upper ball joints
A/C condenser fan
09/2017
Hid retrofit , Morimoto d2s, 6500k bulbs, 35w ballasts, Apollo 3.0 shrouds
All pics low beam, unedited
MJT 4runner Grille
10-2017
Plastidip'd trail wheels Obsidian Black Pearl
So I had sold the 2001 and bought a silver 99 4wd w/locker shortly after in 2019, as seen starting on post #28. However i was rear ended on the way to work in 2020 and it was totaled. I then picked up a white 97 4wd manual that I've done mostly similar mods to. I must say the manual has made daily driving a 5vzfe 3rd Gen much more enjoyable.
97 4wd manual
Looks good! When the mod bug hits, it hits hard. When you find a good deal on a hood, jump on it. They don't last long.
Craigslist find, sport hood complete with hardware and insulation
Led drl switchbacks under the filler panels
Also picked up some Morimoto Mod pods to retrofit in place of the stock fog lights.
Test fit, seems to be warped slightly or needs some adjustment or body work , sits low on the driver side. Paint coming soon...
Nice truck! The bump stops for the hood are adjustable. If it's sitting low on one side I bet that side just needs to be raised. They just turn to get taller or shorter.
Nice score on the sport hood. I would love one of those. Nice clean looking rig man!
Ahhh... that's handy to know. Thanks for chiming in Unner.
okay, I saw the pug sticker, can we get a photo of the little fella next time you do some pictures? Maybe a classic, rear window down with his little nose sticking over the edge, lol
PS 4runner is so clean, kinda jealous!
I had brought them all the way up. I ended up making taller ones out of shock bushings to hold it level with fender.
I will be sure to do that haha! He loves ride alongs. [emoji16]
Hid projector retrofit complete. I like these just as much if not more than the ls460 projectors on my Tundra. Mounted the ballasts inside the inner fenders to keep them dry and engine bay clean. Lights up the night and no blinding oncoming drivers.
Depo Housings
Morimoto d2s 4.0 Projectors
Morimoto d2s 6500k bulbs
Morimoto xb 35w ballasts/igniters
Apollo 3.0 shrouds ( trimmed)
Paint matched reflector bowls
All pics are low beam, unedited
Plasti dip'd the trail wheels Obsidian Black Pearl. Has multi color flake in it you see when the sun hits it.
NVBASSJUNKIE
