brake bleeding abnormal situation
97t4r81
I got a 99 that I went to bleed the rear brakes. But the fluid only comes out from the threads. I only opened it an 1/8 turn while pumping. I just did this yesterday with no issues. Any ideas? This seems abnormal. Thanks
You probably have gunk in the bleeder screw's nozzle. Replace the bleeder screws and put a cap on it.
Or just clean the old one out. Pull it, use a needle and some brake clean then put it back in. Good to go. I had to clean out 3/4 on my corolla as there were no caps on them. As above, get some rubber caps when you re done.
Thanks y'all. Going with speed bleeders. I hadn't seen them get clogged up and not work before. Thanks again
