Brake Fluid
Louie
What brand and spec brake fluid do you use for your late model 4Runner, 2003 and newer. How often do you change it and does anyone use the old fashioned pump and bleed method?:)
I use ATE (super blue or super yellow) brake fluid. Very high boiling point and less water adsorption. I use a 'Mighty Vac' bleeder. Easy to bleed brakes with one person. Empty the MC with a turkey baster and fill with blue. Starting with the caliper furthest away, draw a vacuum and open the bleeder. Keep pulling until the fluid is dark blue. Then re-fill the MC and proceed to the next caliper.
I usually flush the fluid every 2 to 3 years. After a blue fill I will then use the ATE Yellow for the next. Just a lot easier to see when the line has been fully flushed.
Butch
Doesn't it turn green :D
Oh I forgot to mention in my original post that I use the old pump and bleed technique too. With a bike it's easier to do by yourself but on a car I find it's easier with two people. Un
DionicioLives
