Brake line length - 2-3" lift
Monkeyelvis
Does anyone know offhand what the length for new brake lines (Front and Rear) needs to be when lifting 2-3"?
I've done searches on here and YotaTech and can't seem to find this info. Thanks in advance for any input you guys might have.
Do you mean all new lines or just an extension to compensate for lift? If you just mean extension then its not really necessary. I bought the kit from toytec to extend the rear just cuz I had the cash at the time but a lot of people run without it. And the front doesn't need extension.
I was going to replace them with so stainless steel lines when I do the Tundra brake upgrade. That was the main reason for doing it, since everything will already be apart.
Extended fronts are not necessary, for the rear a few of the members have mentioned they just bent the brake line bracket on the frame down and that gave them all the slack they needed.
