Brake Lines
MikeInNH
Anyone ever replace the OEM brakeLine...the line that connects to the calipers????
I'm looking at replacing mine with a stainless brake-line hose.
If so which ones are you using and where did you get it???
None of the local auto-parts sell them.
Stoptechs or Goodridge. I got my Goodridge thru a local toyota shop. I believe they got them from worldpac
What kind of improvements can be expected from this... also what kind of prices....
I would love to lock down my brakes (My Brakes are spongy and i usually feel the need to double pump to get the pressure I need to stop appropriately.)
Great recommendation.
I already posted this in your other thread, but if you have to double pump the brakes, you definitely have air in your lines. Get it flushed out again properly. SS line will give you a firmer brake pedal feel. You should be able to lock up your brakes if everything is in tip top shape.
Thanks guys.
That's exactly what I was looking for.
I don't expect any performance increase....I'm just looking to make the changing of the calipers easier. Since I seem to be doing them about once every other year (about 80k miles).
lindwlson982
