brake switch wires
How do you reach them? I need to get ahold of the green and white wire.
If you prefer, you can access the same signal in either the right or left kick panels, or in the back of the fuse box by driver's knee. Post your year if you want detailed help on something like this.
Sorry I thought I did include it. Its a 1998
I just need a 12 volt activated by the brake pedal
The destructions say in the wire coming from the brake switch so when you hit the brakes to put the truck in gear it disables the remote start
I said, "Where?", not "Why?" You have four easy options, driver j/b, either kick panel, or at the switch. I'm not going to type details for all four.
[MENTION=102597]IBallEngineer[/MENTION] Damn right, you don't!!
Well. Which one is the easiest to access? The wire coming out of the switch is not accessible
Let's go with the kick panel
I have no idea which is easiest--I just know they are there. But left kick panel sounds like a good bet. So your green/white wire is in connector IE2, a big whitish one with 22 pins, at Pin #10. Pin-out of Connector IE2 is shown on page 39 here:
