brand new Daystar 2.5/1.5 lift
TNTramair
well i ordered this Daystar kit and 2 days later i fell into a free 3" strut and spring lift so i wont be needing this anymore. the kit is brand new and has never been installed.
$150.00 shipped.
paypal accepted if you pay the fees (if any).
dropping some knowledge with a free bump...no fees when you send payment as a "gift" which you can only do if there is no invoice from the seller
part# Kt09115bk
description from their website:
Daystar Lift Kits combine the same proven technology found in our Leveling Kits but with the addition of rear lift. Daystar was the first to enter the Leveling Kit market in 1995. Though there have been many companies that have entered the market since, Daystar's Lift & Leveling Kits offer many advantages that the others can not claim:
* No Metal-On-Metal Contact - Daystar uses Polyurethane material in its Leveling Kits for a reason: It's an insulator. It absorbs the Noise, Vibration, and Harmonics (NVH) that come from the suspension and avoids transmitting them to the passenger compartment. All competitors use steel or aluminum in their Leveling Kits. If you were to take apart any factory suspension, you are going to find rubber, polyurethane, and often both in a typical suspension. These pieces are there for a reason; they absorb the NVH. Sure, steel makes a great hammer, but would you want to ride on it?
* Lifetime Warranty - All of Daystar's Lift & Leveling Kits are backed by a Lifetime Warranty. Basically, in the unlikely event you experience a problem with a Daystar product, we'll take care of it.
* Made in the USA - All of our Lift & Leveling kits are manufactured at our plant located in Phoenix, Arizona. Most other Leveling Kits are manufactured overseas. In-house manufacturing ensures a level of quality control that no one else can match....and we have the ISO9001 certification to prove it.
* Top-Mount Easy-Install Design - Most late-model vehicles have gone to a strut type of front suspension. Most of Daystar's applications are a Top-Mount design, meaning that our components bolt to the top of the factory strut assembly. This type of leveling kit does not preload the factory coil spring, so factory ride quality is maintained, and installation requires only simple hand tools.
Daystar Lift Kits work within the factory suspension design, meaning that we work within the factory's design parameters to achieve an increase in ride height. Because we work within the factory design, there are not a bunch additional modifications involved that adds complexity and expense to the kit. Everything needed is included in the kit; there's everything you need and nothing you don't. If there are extra items required, such as longer shocks, it's clearly stated in the application description.
Daystar Lift Kits provide both front and rear lift in the 2" to 3" range. Front lift is generally the same as with our leveling kits, while rear lift comes in the form of rear coil spring spacers, longer shackles, add-a-leafs, or a block and U-bolt kit. Which method used is spelled out in the application description. Daystar's Lift Kits are the perfect solution for gaining ground clearance and the room to step up a few tire sizes...Do your homework and you'll see that we've done ours!
Features:
* ComfortRide™ Suspension System; Lift Kit
* Lifts Vehicle Without Sacrificing Ride Quality or Load-Carrying Capacity
* Increase Vehicle Height/Enhances Performance
* Maximum recommended tire size: 32"
* No Metal-on-Metal Contact as with Other Leveling Kits
* Limited Lifetime Warranty
* Includes Front Strut Spacers and Rear Coil Spacers
upanatāt
