breathers
was going to link all of the breathers to one manifold and mount it to the firewall.
should i do an open air filter or a one way check valve?
the stock rear diff breather is not really a breather but rather a check valve. didnt know if all of the other ones were the same.
That's the way the Australians do it. They use sintered brass porous mufflers, all mounted on a common bracket in the engine bay.
Get the ARB kit.
Last I checked if I remember correctly. The transmission and transfercase have the same design style breakers as the axle. But they are pressed in.
I want to extend THOSE !!! I have a mani transmission. And there is a breather on the shifter, a breather on the transmission and looked like a breather going from transfercase to the housing part where the tcase mounts to the transmission.
bobdjr41
