Brembo rotors... but what pads? Akebono or Brembo
DaveInDenver
2002 SR5 auto 4x4 15" 250K
About to pull the trigger on some Brembo rotors (not slotted) (297/11.69).
Have seen posts that Ake' pads have been picked for Brembo rotors. Why is that a fav rather than going also with Brembo for pads?
(FYI, 4Wheel Parts shop does Power Stop Z23 all the time. But said Brembo are better.)
I use that combination Brembo rotors (not slotted)09.B461.11, and Akebono ceramics. Very pleased. Akebono cause good reputation, no other specific reason.
(2003 V6 2WD)
I've used both brembo and akebono pads.
Akebono Pro-Act ceramic, hands down.
my Brembos dusted like crazy. Akebonos produce very little to no dust
unless akebeno has changed the pads in past 4 years, I was not that thrilled with them, and they dusted a lot over stock, in my opinion. However I drove lots of hills and heavy brake use. They were ceramic, but not the newest version PRO-ACT . So maybe not a good comparison.When I did my TBU I went with Toyota pads. My new to me 2001 has Toyota pads and brakes feel good.
I would upgrade instead to the Tundra brakes instead of going Brembo rotors for the 15" wheels.
What you'll need:
1. 16" or 17" wheels and tires - because of the offset, some 16" wheels will have interference issues with the 231mm Tundra brake calipers.
2. 1999-2005 Tundra brake calipers - 231mm or 199mm calipers
3. 1999-2005 Tundra brake rotors and brake pads
HTH
matisgugle
