Yes that's going to be my topcoat on the rigs when finished fixing.Thinking I will try Cosmoline on the drums and see how long it lasts?
I painted my drums about 3 years ago while doing all the rear control arm/ panhard bushings. I bead blasted them, tremclad red oxide primer, tremclad black paint thinned down both brushed on. Sprayed with VHT high temp clear meant for brake calipers, been holding up great.
I think cosomile would stay as a top coatWhen I painted mines, I just did the regular no frills wire brush down to clean metal and VHT caliper paint on bare metal. I don't live in a salt state, so I cannot say how it will do in your area but, so far it held up here down south.
I'm about ready to go on my second set of caliper pads on the tbu set up.
Can a base waxy film survive the heat front brakes put out long term? I would think the film initially would gas out, then turn into a tar like texture. Or maybe dry up from repeated heat cycles, rendering the once waxy film into rigid hard paint like coating.
No idea. Transmission fluid will last about 6 months or so.Wonder how linseed oil would last?
These baby's arrived...stainless steel.
Sent from my SM-J337V using Tapatalk
Thank you for the feedback. I plan to rebuld the one caliper myself. I looked up my larger ones and they require the same bleeder.16" Limited wheels will fit the TBU I've read, my T4R came with worn out snows on the factory wheels where previous owner rattle canned them poorly they've been stacked behind my shop for 5 years I'm scrapping them next week. I run standard common taco 17" as winters and 17" common FJ wheels as summers. I believe it was the reman procedure on the calipers that caused the bleeders not to fit - smaller threads. I ordered 2005 tundra 4x4 calipers and the speed bleeders to match still didn't fit. Speed bleeders are great! 2000 Limited with 16" factory wheels no spongy pedal after upgrade. Tow a double seadoo trailer and a 5 x 10 aluminum trailer no problems since upgrading 2018.
No, the sport package did not change the rotors/calipers. Only on the 4th gens did the sport package upgrade the front brakes... 3rd gens only had two brake options, for the 16" wheel trucks and the 15" wheel trucks.I believe your 01 Sport will have the larger calipers as well since that was part of the Sport package.
199 vs 231 calipers is a CALIPER measurement. The rotor for both is the same. Same diameter as the stock 4Runner rotor but thicker.
You can keep the brakes from 'warping' with careful brake application. What you are feeling is brake pad material deposited on the rotors, not actual warping of the rotors. As you come to a stop, you need to ease up significantly on the brake pressure for the last ~1 car length to lightly 'smear' the material across the rotor. I drove many thousands of miles on 32" tires with the small brakes (1" smaller rotor diameter than you have) with zero 'warping' - after starting with fully 'warped' rotors when I got the 4Runner back from my sister...
Now I have the 231 Tundra upgrade on there... :wave:
-Charlie
Possible remain like you said used bigger thread would be my guess.I had trouble finding the speed bleeders for my last TBU....maybe the russel site is wrong....maybe when they reman them they re-thread?
they sure are handy.....good luck
My pressure bleeder is awesome.
Fill it with fluid hook it up to the MC and put 5-15psi on it and then go around and open up each bleeder.
I never used a power bleeder or one that holds a vacuum on the master cylinder. I mostly use a hand bleeder with a reservoir and the bleeders. Being the bleeders rust up around here I figured I try the stainless steel speed bleeders to eliminate a frozen bleeder issue as well as faster to bleed.Love my Motive power bleeder as well. I use it dry and topped off the master twice when I bled my 02.
Zero cleanup when used dry to pressurize the system.
Speed bleeders are the next best thing
