Going to see how I do welding aluminum. Might need to make a few things out of it.
Maybe some bumpers. Brush guards to keep the deer away. I could use a few toolboxes.![]()
Sent from my SM-J337V using Tapatalk
Ah. So your going to tig your sleeping platform..When I make my rear storage/sleeping platform im going to use aluminum square tubing as the structure and I’m going to use brazing rods to join them. They seem pretty legit for what it is.
Bernzomatic AL3 Aluminum Brazing/Welding Rods with 12-Inch Rods of Working Temperature 720-750 Degrees, 2-Piece Bernzomatic AL3 Aluminum Brazing/Welding Rods with 12-Inch Rods of Working Temperature 720-750 Degrees, 2-Piece - Arc Welding Equipment - Amazon.com
Ah. So your going to tig your sleeping platform..That's the one piece I am missing yet a tig machine or a tig kit for my welder.
My spool gun is a mig weld with aluminum. Has a spool of aluminum wire in the gun.
The price doubled since last year and I wanted to get one before it doubled again.
Ah.. understand.No those are not for tig, you just use a mapp gas torch like brazing copper.
Not a bad idea. I needed to get them coated quickly. As you know how fast metal rusts after being blasted in this environment.When I do stuff like that I’ll heat the metal lightly with a torch until I see the moisture start to collect and then evaporate/dry off. And while it’s still warm I’ll hit it with paint.
