Broken Filler Panel/Headlight Bracket?
Big-Boy
Hello,
I'm sure this has probably been covered before, but search as I may I could not find it. Everything I could find had to do with headlight replacement itself vs. the bracket.
There is this black plastic bracket broken on the driver side of my 1997 that is leaving the filler panel, headlight, and grill all loose. It seems as if they all connect at the same point.
In the first two pictures you can see the passenger side bracket intact. In the last picture you see the drivers side broken and missing.
Anyone know a part number for what all needs to be replaced here, and where to get it?
Thanks for the help!
<blockquote class="imgur-embed-pub" lang="en" data-id="rSJhkJ7"><a href="https://imgur.com/rSJhkJ7">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
<blockquote class="imgur-embed-pub" lang="en" data-id="ATHgoZ8"><a href="https://imgur.com/ATHgoZ8">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
<blockquote class="imgur-embed-pub" lang="en" data-id="Rh9Nikr"><a href="https://imgur.com/Rh9Nikr">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
When I need an OEM part or #, I call my dealer parts guys.
But you may also want to merely check with a "pull ur part" type junk yard. They're cheap, just gotta hunt for your part....
Luck and enjoy the Runner. :COWBOY:
Thank you. I want to find something at a salvage yard as I want to do a center console swap as well, but I have been unable to find any 3rd gen 4runners around me in the junk yards.
I think I have one of these used. You can also check with 4RunnerHouse in Garland, TX. He sells these used for like 50-60 bucks with all the adjusters.
I now this is a very old thread but looking on Ebay, CarId, NAPA auto parts, and a bunch of other places for the mounting bracket will probably be cheaper than buying direct from the dealership or an OEM parts seller.
Crookedcat
