Building, Driving and Adventuring the MTN4RNR
I still come to this thread to stare at that pull out table. Freaking love it :thumb:
I lined the 2 lights up to my liking and drilled 2 holes each with a step drill to get a smooth hole. I then made a notch per light on the outer edge of the panel to route the wire inside the hatch.
Laid out for alignment
installed!
I was about to send you a message asking for this information since it wasn't listed on the first page. Searching works!
You mentioned you notched the side of the plastic. Could you have drilled a hole behind the light to completely conceal the wire?
Searching is awesome!
The wire for the light comes out of the side of the housing, and I suppose that you could drill a hole right at that point, but I didn't want to put any strain on the wire at the point of connection to the light, so I opt'd to show the wire and run it through at the edge of that small panel.
When you bring the new truck home, and the lift gate doesn't clear the overhang... Custom limiting strap, installed. Uses a Nite-Ize CamJam XT on the d-ring in the corner, and a carabiner attached to the lift gate strap.
Function>Form
IMG_4647_zpsh2128rfk.jpg~original
doesn't the carabiner jam between the gate and sill?
The carabiner is unclipped and stowed on the right side when you close it. So when I open it and need to be in and out for a bit, I will grab the carabiner as I am opening it and clip it on. Then unclip when I go to close. Not perfect, but it's cheap and it works :thumb3:
Ahh...I do the same with a bungee but was hoping to not need to hook it on every time.
Nah. Cheap and easy for this mod. I actually ended up raising my carport in the end. So I don't do this too much anymore.
I cant raise my garage door :) . I was debating doing something like you have and then a piece of bungee attached to the rope to pull it in as the hatch closes
In theory, you could remove the 10mm bolt that holds that strap on, thread in an eye nut, and tie your paracord to it and eliminate the strap/carabiner. Then when you close the door, you just kinda toss the excess inside as you close it. Not perfect, but it could be an easy solution.
Hmm, I'll have a look tomorrow
One of the most important tools to have when adventuring in remote areas is a good communications system. CB radio had long been the tried and (sometimes) true source for inter-vehicle communication. This loyalty has been changing more recently in the off-road scene in favor of a far superior form of communication; HAM radio. HAM radio, more technically known as VHF/UHF is uses higher frequency range to establish a clearer signal over a farther distance. However the most important advantage to using HAM over CB is the ability to use repeaters. With proper use, a well placed repeater can extend one vehicle’s range over hundreds of miles. And anyone that explores remote places without cell reception knows how important this ability can be.
I started my HAM career with a single Yaesu FT-60r, soon after buying a second as a back-up. The reception was good for a handheld, and it was easy to get acquainted with while I was learning the basics of HAM communication. After a number of trips, and a few instances when the range wasn’t enough with the Yaesu, I realized that I wanted to upgrade to an installed mobile unit in the 4Runner. I had a short list of requirements:
  • Dual band operation to monitor multiple frequencies
  • Removable faceplate to allow me to mount the head unit in in 4Runner without taking up a lot of room
  • Cross band repeating capabilities so allow for a hand held to “tap” into the mobile unit and extend it’s range
  • Built in weather channels for monitoring changing conditions
Choosing a Radio
With all of those requirements in mind, I ended up with two choices; the Yaesu FT-8900 and the Kenwood TM-V71A. Both filled the requirement list, and there were some subtle differences. The Yaesu is a Quad Band radio, which opened up a few more options if I were to up my license to a General, but for me it didn’t really count as a plus. The mic on the Yaesu plugged into the movable faceplate, and the Kenwood plugged into the main unit which meant I would need to put it close enough to me so that the mic cord would reach me when plugged in. In the end, I chose the Kenwood. It had a more mounting friendly face plate, it was green or amber backlit (I use green), ALL of the buttons are backlit (something that the Yaesu doesn’t have), and in general it felt like a better fit in the 4Runner. Either one would have done the job, but I liked the TM-V71A best.
Installation
The Head Unit:
I wanted it to be in a place where I could easily see the screen, and adjust volumes/squelches without diverting my eyes from the road or the trail too much. Looking down is never a good idea, so I started looking at the top layer of the dash. To the left of the instrument panel would have meant fabbing a mount, and then having the unit be closer to a window (more of an attention grabber for would be thieves). Centered on the instrument panel, or mounted on the steering column would have been a good option if adjusting anything or pushing any of the buttons wouldn’t have required me to reach through the steering wheel, so that was out. I settled on the center of the dash, covering the clock. It’s a flat space, and with the height profile of the faceplate, it barely rises above the upper dash. I used a standard cat5e cable to extend the faceplate to it’s location, and then a female to female adapter to allow for the extension cable to connect to the provided cable which plugs into the faceplate. A pretty easy solution to extend the faceplate wherever you like!
The “Brains of the Operation”:
I mounted the main unit of the radio in the center console for a few reasons. First, it needed to be close enough that I could plug the microphone into and still have it conveniently reach me in the driver’s seat. Kenwood does offer a “remote kit” for their radio that includes cords to extend the faceplate, and the microphone jack. But this kit is rather expensive, so I used cat5e cable to extend the faceplate, but I didn’t want to use a non-shielded wiring setup to extend the microphone jack because the internets told me that it might effect my sound quality in the 4R and to others listening. Below the driver’s seat is the most common place to install the main unit of the radio, but with the microphone reach being an issue, that location was ruled out. So, in the center console it went. This location ended up being a great place to place the brain as it is out of view, more dust/water protected than under the seat, allows for the mic to plug in and come through the factory cord grommet in the center console, and in general it is a much cleaner installation. I used the stock mounting bracket, drilled some new holes to bring it as close to the side as possible and mounted it with 3M extreme fasteners meaning I can remove it easily if needed, and no drilling into the console aside from the grommet hole I drilled at the bottom to bring the wires through. If I were to sell the 4R, a quick plastic plug would make the hole disappear to a new owner.
The Mic:
The microphone plugs into the main unit in the center console and runs through the factory grommet under the lid. I mounted the mic to a Nite-Ize Steelie mount to the left of the shifter. This allows for an easy reach to the mic, and it makes it really simple to grab and put back as there is no physical clip to slide into like the one provided with the radio. I highly recommend this mounting option because it’s so simple and convenient. When the radio isn’t in use, it fits perfectly in the kleenex holder on the lid. Incognito.
The Speaker:
The speakers that come built into mobile HAM radios with removable faceplates are notorious for being very quiet. The easy solution is to purchase an external speaker. I went with the Kenwood branded external speaker (I know that there are much cheaper alternatives, but there is something nice to be said for having a matching set of logos on the dash) and tucked it into the lower console cubby that I seemingly never used. It’s centered on the dash, so the sound comes through evenly and in line with the faceplate, something I appreciate. I used double sided tape to secure it in place, and through Death Valley and a trip in freezing temperatures, it hasn’t budged and it is plenty loud to hear with the windows down.
The Antenna:
I used a Diamond trunk mount to mount the antenna to the passenger side edge of the hood. This will keep the antenna in my sights as I navigate trails and trees, so I can lower or remove the antenna to avoid damage to it on the trail. My trip antenna is a 38” Diamond NMO antenna, and my everyday antenna in and around the Bay Area is a 16” Comet NMO antenna. Both have performed well and have shown good feedback on the trail and on the road.
Thoughts:
The mobile unit is definitely the way to go if you are in remote areas, or need the power and capability to reach far away repeaters or contacts. I was recently in a situation where the group I was in had a mechanical failure, but using the radio I was able to make contact using a repeater 35 miles away located in a local town. I was able to let a small group of HAMs know our location, and expected time back to town. We had no cell service, so the radio was our only point of contact. I was thankful that I had the ability to reach out if we needed it, and thankful that I had the equipment to do the job.
where did you run the cable the radio head?
It runs from the center console, under the cup holder/shifter panel and up through the radio paneling. You end up taking a lot a part. I removed the center console paneling (cup holders, shifter cover), the climate control panel and surrounding trim, and the radio head unit. It was a bit tricky, but with some basic knowledge about auto clips and fasteners it's pretty simple to pull apart to route your wiring.
sorry I meant how did you route the wire from the head into the cavity behind the radio, did you drill a hole? Ive had the dash apart a few times, I cant picture how you got the wire out up by the clock
I drilled a small hole on the left edge of the clock fascia that you can't see. It's more of a notch where the radio trim piece meets the clock fascia. So the wire was routed between the two pieces. If I can get a decent shot with a camera, I can post it here later tonight.
Here is a photo of how the wire comes through to the face plate. Hope it helps!
Max, whatever happened to that RAV4 mirror? I haven't seen it lately. I really liked that basically OEM convex mirror; thinking about doing that little addition to my truck.
2001ATL
