Building, Driving and Adventuring the MTN4RNR
Here is a photo of how the wire comes through to the face plate. Hope it helps!
I'm the process of installing this same radio in my 2012 SR5. Thanks for posting a write up on your experience, it has helped so far.
What kind of adapter/coupler did you use to connect the two CAT 5e cables for your face plate?
It appears that the small 3.5" piece of cable that comes with the radio to connect the main unit to the face plate has two different sized ends. Did you salvage this piece of cable or use something else?
Did you use just regular shielded CAT 5e cable?
Thanks!
Thanks!
I used an unshielded female to female RJ45 connector just behind the faceplate. I used that 3.5" piece, and attached the connector on the end of it and to the new CAT5e extension cable. Because I was just extending the face plate, I used an unshielded CAT5e cable. I haven't had any adverse effects since I installed. Had I extended the mic, I probably would have gone shielded, just to be safe. Let me know if you have other questions :thumb3:
When I first bought the 4Runner, it didn’t take long before I realized that I would need to modify the stock cargo area to best fit my personal needs. I had a few basic requirements to consider:
Cargo Security:
My typical cargo usually consists of the Ruff Tough kennel for the pup and a Front Runner Wolfpack (used to be Action Packer). When I switch to camping/Overlanding mode, I will typically add my camping box (DeWalt Tough boxes), the cooler, and other miscellaneous small items. All of these things needed to be secured in case of a collision or other accident. The last thing that I want is for the dog kennel to smash around, or to see a fully packed Yeti cooler cruising through the windshield. A tie down system can also be more practical by keeping your gear secure when four wheeling as you start/stop/pitch/jolt. It was really clear that the stock 4 point system wasn’t going to cut it after a few 4wd trips, however for the better part of a year I have made it work.
A Fully Flat Cargo Area:
The 4Runner (without the OEM cargo tray) with the rear seats folded down does not allow the cargo area to be flush with the rear seats. It’s about a 2-3 inch drop, and that drop makes a huge difference when it comes to sleeping comfortably in the back. Like my issue with securing cargo, I was able to make it work using a yoga mat, and an extra blanket. It worked, but I slept terribly.
Additional Preparation Space:
When I camp and spend time outdoors, I tend to need a flat surface to perform various tasks. Cooking, organizing gear, working with maps, etc. In the past I have made due with cooking on my camping box, requiring me to pull everything out that I will need for the meal, and ultimately I forget something mid-cook. How hard is it to open the camping box while there is a full pot of water boiling on the stove? It’s very difficult, trust me. Sparing myself buying a table for camping, I thought having something that could be easily deployed when needed would be a great addition to this platform.
Room for growth:
When I design/start any project, I understand that even if it is well planned, and even better built, there is always the likely possibility that I will find some way to make it better. So I incorporated that reality into my build by using materials and a general layout that would allow me to incorporate drawers, a fridge slide or anything else later on down the road.
Note:
I won’t be going into full design details with this particular project at this time, mainly because I am contemplating doing a small production run of this platform once I give it a good shake down to test the integrity of my design. Once I can establish that there aren’t any weak points, I will consider moving forward if there is a suitable demand. In the meantime, I will be pricing the unit as it is currently designed because I understand that the first question many ask with this sort of product is “How much?” That’s what I am going to work out.
Product details:
-Baltic birch plywood construction
-Aluminum L-track tie down strips with movable tie downs
-Line-X platform coating
-Stainless steel hardware
-Minimal modification of the 4Runner to fit (plastic trim removal; no cutting)
-Flush to seat design
-Slide out preparation space
Product Description:
The platform is constructed using strong, Baltic birch plywood. It is made of a hardwood ply, and unlike cheaper substitutes, it doesn’t use a weaker filler between the layers of hardwood. It is hardwood through and through making it very rigid and durable. The plys are bonded together using marine grade adhesive, and the outside veneers are thicker allowing for a more durable surface. It’s not a cheap material to use, but the benefits well outweigh the cost.
The platform incorporates 4 aluminum L-track strips. Left, center, right, and against the rear seats. Each one with approximately one tie down option every 1-2 inches. This means that as cargo needs change, so do the tie down points. This variable approach allows for securing different cargo in different arrangements without compromise.
A Line-X finish on the platform was used to increase the base material’s overall strength, provide a waterproof finish to the top surface, and to increase the long term durability of the platform. As an added bonus, it ended up looking like something that should have come from the factory as it closely matches the plastic color.
The slide out is made of the same Baltic birch plywood, but with an added polyurethane surface protectant to seal it from water and other stains. The edges have been routed to provide a smoother grip when extended. The slide can come out approximately 18” with enough rigidity to hold a stove and food preparation supplies. It is branded with the Mountain 4Runner logo on the lower right corner.
The platform attaches to the 4Runner using existing threaded holes, and only requires the removal of 2 plastic trim pieces. No cutting is required for installation. It fits with approximately ½” per side to spare, and enough room to fold the rear seats up and down without interference.
Product photos:
DSC04575_zpsgddigbti.jpg~original
DSC04565_zpsqat0eiqt.jpg~original
DSC04559_zpsiqwfjspe.jpg~original
DSC04558_zpsnwkhbhos.jpg~original
DSC04566_zpsbpjdtdgs.jpg~original
DSC04569_zpsinimfmli.jpg~original
DSC04572_zpssju4trm0.jpg~original
http://i1380.photobucket.com/albums/ah175/mtn4rnr/4Runner%20Platform/DSC04581_zpsen3nguxk.jpg[img]
[img]http://i1380.photobucket.com/albums/ah175/mtn4rnr/4Runner%20Platform/DSC04578_zpsljtsfvxl.jpg~original
DSC04583_zpsuikvvbuw.jpg~original
DSC09988_zpsaasyban0.jpg~original
DSC00002_zpsn135wyty.jpg~original
DSC00033_zps7boz7ner.jpg~original
As I mentioned above, I will be testing the platform in the coming months and determining if I can produce a small number of units and what the associated cost would be. I will update the build page with information as it comes. Feel free to send any questions to me via the personal message feature on the forum.
More to come…
WOW...!!! Really like this [MENTION=129593]MTN4RNR[/MENTION] how can I get on board for one..?
Cargo Security:
Room for growth:
Note:
Product details:
Product photos:
More to come…
Great idea. I want to make a flat cargo space too for the back of mine. I like this idea or the one that Antman did for his. I really like how you incorporated a pull out board though, that would be a great spot for me to make my morning coffee in my jetboil. Last time I did this in the back cargo area I over boiled and it went all over the carpet :frusty: At least it was just coffee grounds and water
http://www.toyota-4runner.org/5th-gen-t4rs/92013-antmans-thread-14.html#post876313
One of my favorite rides on here.
I'd love it if you could post the drawings for your rear deck.
Looks fairly simple construction wise. Just a ton of measurements that I'd truly hate to recreate.
Just finished reading this in its entirety... great write ups brother. We just got my wife a 17 TEP and I'm itching to start modding. But still not sure the direction I want/need to go living in SE Texas. We're more Jeep country unfortunately.
I can say one thing, reading all your adventure reports makes me want to hurry up and move back west!
I joined Overland Bound a while back on the forum, and upon arrival of the 4Runner in my life, I ordered the emblem and plan on being more involved in their expeditions. They just completed their first annual Off the Grid overland rally in the Sierras.
Check out the wrap up videos:
https://www.youtube.com/watch?v=83NrtwWME2I
https://www.youtube.com/watch?v=A6zZ5KvmsAQ
I can't wait to attend next year, and hopefully join along on some trips in the mean time. If you haven't already, check out their website! Overland Bound - Overland Bound
IMG_5076_zpsjwxjslgu.jpg~original
Did you get two emblems or just one? I'm trying to decide if I want one for each side or just go with one side or maybe just one on the back.
Thank you very much! The nice part about starting a build is that you can take your time to figure out that direction. No need to rush, that way you end up with what you want vs. what the forum tells you that you want... Trust me, it's a slippery slope! The West is amazing, and I haven't even seen a fraction of it!
I have just the one emblem on the driver's side. It's fun to have, but I don't need to over advertise it either, so one is enough for me :thumb3:
Bump.. Did you ever decide if you were going to sell any of these, or were you going to just make a "how to"? :cheers:
I'm looking at doing something very similar as I like how you have tie down points so if someone wanted to install drawers they could be easily removed if they just strapped them down.. I'm kind of thinking of a similar platform, yet slightly higher so I could store a fold out table underneath, and then have the board just on the drivers slide as a pull out and use the passenger side to make a slide for my arb fridge and parter stove.. Like the GooseGear one, just not $1700 lol.
P.s. I just read through your entire build at the expedition portal tonight at work. Definitely one of the top build threads..
I gifted myself a set of [MENTION=12905]XenonDepot[/MENTION] Xtreme HID's for the low beams on the 4Runner.​
Before (no fogs)
image_zps5hbd1ykl.jpeg~original
After (no fogs)
image_zps1vukulrj.jpeg~original
Bought the same kit and completed the install today. The before and after picture sold me - you can't even see the car on the road in the before picture! :thumb:
I assume it's normal to hear a high pitch whine after turning the lights on for 10-20 seconds before they're warmed up?
BTW, great thread! Looking to copy a few more of your ideas in the future.
