Bulb socket rubber seals
Carl_G
Member
Does anyone know the best liquid use on the rubber o rings on things like headlamp sockets, parking lamp sockets etc. Specifically where the wires clip onto the socket and there's the rubber seal. Would hopefully make it easier to remove at next bulb change.
Thanks!
You should only be using dielectric grease where there are electrical connections.
i recommend dielectric grease for connector terminals/pins and i use a spray silicone like 3m on the seal. it lubricates but its dry. use it at work on connectors all the time. works great
AndiGarage
