Bump then no power
AZZTR0CREEP
i was on my way to harbor freight, pulled into the lot over the dip and lost all power. i can start the engine but then it seems like something is telling it to turn off. ill start it again and right away something is shutting it down. i gave it a kiss and it still happened. what now
It's cranking and not turning over. I am guessing fuel pump if it's the original most likely cause. Throw some fuel starter in it and fire it up if it comes to life then it's the fuel pump.
bought a bluetooth scanner
i bought a bluetooth scanner and my error codes are;
p0100 mass air flow circuit
p0110 intake air temp circuit
p1300 inginter circuit malfuntion no.1
maybe these are easy fixes
Check your MAF connection. If it comes loose it will do exactly as you are describing. Start then stall within a few seconds. It's the plug just upstream of the air box filter.
the 2 wire pigtail on the 2nd ignition coil had a broken clip. as soon as i secure the connection everything magically runs.
D'Angelo
