Burning metal smell
texadelphia
I have to drive up a steep 1.5 mile long hill regularly. I sometimes stop at the post office at the top of the hill. I've noticed when I come out of the post office and restart my rig, I'll get a waft of metallic burning smell that comes in through the vents that dissipates pretty quickly. I used to notice a similar smell from my Audi after climbing the same hill and just thought it was the turbo heating up. Any thoughts on what it might be?
Sent from my moto x4 using Tapatalk
You are getting a heat soak condition. Your engine builds up a lot of heat on the climb up. If you then quickly shut it down the coolant stops circulating and you get high temps in the engine. If you have a scan gauge you will see a very hot temp for a few seconds when you fire it up again.
Good practice (and recommended for some turbos) is to let it idle for a couple minutes before shutting it down to allow the engines internal temps to stabilize. That should eliminate what you are smelling.
I had heard about this previously but installing an ultra gauge gave a good visual of what happens.
Thanks, this totally makes sense. Glad it's not a sign of something more sinister.
REE
