buy once, cry once performance upgrades
So what’s involved in a supercharger install?
Some throw some numbers at me and how DIY is the install? I’m fairly mechanically inclined but don’t know much about Toyota engine stuff.
It is ridiculous as to how easy and straightforward the install is. Especially if you get the dynamic tensioner. If you add a 7th injector, then it starts to get a bit more involved.
Your pretty much swapping out the stock intake manifold for the supercharger. 5-8 hours max.
http://www.toyota-4runner.org/3rd-gen-t4rs/53420-what-does-ect-button-do-really-3.html#post2355588
Here's one example, but it's not the one I was thinking of. Someone else did a back-to-back dyno run with a stock engine and gained ~5HP. I cannot for the life of me find it though.
In that dyno he did the ECT Power button on after the dyno with it off, so that rules out heat soak killing the numbers for the second run. If they had been switched around the numbers would be even more dramatic.
On a N/A motor, power goes UP with successive runs - hotter/thinner oil explains most/all of the power increase. To do it right you have to do A-B-A testing (minimum 3 runs).
-Charlie
Jkmazon
