Buying used tires
Wuzzy
Im trading my 4Runner in and Im getting beat-up on the price. So I want to keep my General Grabber AT2s that are less then a year old. I found a set of used BFG mud terrains for cheap money. But they are pretty beat. The problem is I am driving 5 hours away to pick up a 2010 tacoma and I dont want to mess up the drivetrain. I have a V8 and I know the tires have to VERY close in diameter because of the 4WD system. What is a acceptable variation in size ?
Are you putting two BFG's on or four? If four, then it should be no problem, if just two then I wouldn't recommend it.
Not an issue. When you see problems is when people put different tires on.
Wear from awake tires isnt going to do anything.
The diameter doesn't have to be super close (i.e. a margin of 6/32" or so should be okay), I personally think Toyota is being a little paranoid with their warning on the Full-Time 4WD, I cannot see how less than a half an inch diameter difference creates a significant enough issue in the all-time 4WD system.
If money seems to matter a lot to you, why not just sell your car private party? There's a few thousand dollars right there. Many of us have done it. It's not a difficult task.
As long as you don't have lockers it won't matter. You have a open differential to alleviate binding.
How much are you saving after buying the used tires then paying to have them swapped? Sounds like an awful lot of work. I am guessing you paid somewhere around $160 each. You are now going to pay probably around $100 to get them removed plus probably another $100 or so for the BFGs. You would be lucky to get $100 a tire used for the generals. You realistically are only netting $200 which doesn't include your time and gas.
CoaterZ_FL
