bypass the dash AC button
Jayson44
Member
my AC compressor works just fine when it gets power, but the dash button doesnt' always send power to the relay. it's goofy...it's always lit up (not blinking) and sometimes it comes and goes. it pretty much always works when it's humid or raining. I took it to Firestone to have them check the AC when I thought it just needed freon, but they told me they tested it and it was all fine except the dash button.
so, how can I bypass that one and just send power to the relay from another button? is this possible?
J.
Ac
I would try replacing that relay. Mine went bad and the light started blinking. I know yours isn't doing that, but they are known to fail so it might be worth replacing before going down any other roads. You could jump the power so that the clutch always has power, but I wouldn't rec'd that. It's better to let the system handle control of everything.
The relay from Autozone is $9, well worth trying as a solution - worked for me and my light wasn't blinking either. Don't get it at the dealer, they tried to tell me it was an $80 part including installation (2-3 minutes of labor?).
I would also try the relay first as it is super common. You can swap it with another one under there if you'd like. I think you only get the blinking A/C light if the relay sticks on and the compressor runs longer than it should, not if it fails to switch on.
Why reinvent the wheel? Buy a new button from Dealer, Rockauto or used from junkyard.
new "button" includes the whole panel, and Toyota wants $1000 for it. :D
I will definitely try this, but the relay looks fine. the guys at Firestone said it was fine as well. but worth a shot.
J.
J.
You really can't tell unless you take it apart. They are cheap enough to try and I swear a stuck one burnt out both my upper o2 sensors. Why else would the heater circuit burn out on both of them? They are turned on by the same relay.
I bought a couple of these from Rockauto, $5 each.
WELLS 1R1696
seltzernator
